Certbot installation / renew
HI =,
and hello busy people, reaching out for help and suggestion
I recently upgraded my Ubuntu 18 to 20 and then things started to not work again
My domain is: www.learninggardenmontessori.ph
Deploying certificate
Successfully deployed certificate for www.learninggardenmontessori.ph to /etc/apache2/sites-enabled/learninggardenmontessori.ph-le-ssl.conf
Failed redirect for www.learninggardenmontessori.ph
Unable to set the redirect enhancement for www.learninggardenmontessori.ph.
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): Ubuntu 20
I can login to a root shell on my machine (yes or no, or I don't know): yes, I can log in.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.29
Welcome to the community @Shazam14
I see http:// requests to your domain redirect to https:// but the https request times out. Let's start by looking at your Apache config. Can you show output of this?
apachectl -t -D DUMP_VHOSTS
