My domain is: suheyl.nl
- sudo apt-get update
- sudo apt-get install software-properties-common
- sudo add-apt-repository universe
- sudo add-apt-repository ppa:certbot/certbot
- sudo apt-get install certbot python-certbot-apache
- sudo certbot --apache
It produced this output: I followed the the steps and enabled it for suheyl.nl
suheyl@KODI:~$ sudo certbot --apache
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel): xxxxx@gmail.com
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/©ancel: a
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: n
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): suheyl.nl
http-01 challenge for suheyl.nl
Enabled Apache rewrite module
Waiting for verification…
Created an SSL vhost at /etc/apache2/sites-available/000-default-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/000-default-le -ssl.conf
Enabling available site: /etc/apache2/sites-available/000-default-le-ssl.conf
Please choose whether or not to redirect HTTP traffic to HTTPS, removing HTTP ac cess.
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Redirecting vhost in /etc/apache2/sites-enabled/000-default.conf to ssl vhost in /etc/apache2/sites-available/000-default-le-ssl.conf
Congratulations! You have successfully enabled https://suheyl.nl
https://www.ssllabs.com/ssltest/analyze.html?d=suheyl.nl
My web server is (include version): Apache 2.4.29
The operating system my web server runs on is (include version): Ubuntu 18.04.4
My hosting provider, if applicable, is: local
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
For me it’s the first time I’ve tried to enable ssl, and just followed the steps which are stated in the manual https://certbot.eff.org/lets-encrypt/ubuntubionic-apache
Installation looked succefull, but can’t reach my site anymore. When I run the debugger https://letsdebug.net/suheyl.nl/121083 I get a lot of errors…
I cannot reach https://suheyl.nl nor http://suheyl.nl
Now I don’t know what to do anymore. Any idea what went wrong?
