After certbot, site not reachable
I am trying to run a nextcloud server from my home laptop. I use Hover for my DNS, and had the A records:
type host value ttl
A @ 108.20.147.223 15min
A www 108.20.147.223 15min
A cloud 108.20.147.223 15min
I also have a CNAME for blog that points to my github pages site (I don't think it's relevant, but :person_shrugging: .
Prior to running certbot, my configuration was vanilla, except for vhosts.d/bonham-ch.conf:
<VirtualHost *:80>
    DocumentRoot "/srv/www/htdocs"
    ServerName www.bonham.ch
    ServerAlias bonham.ch
    # Other directives here
</VirtualHost>
<VirtualHost *:80>
    DocumentRoot "/srv/www/htdocs/nextcloud"
    ServerName cloud.bonham.ch
</VirtualHost>
With this setup, I was able to go to http://www.bonham.ch, http://bonham.ch and get my root page (just an index.html with "Hello, World!", and to http://cloud.bonham.ch which opened my nextcloud installation login page.
After running certbot (see below for outputs), my vhosts.d/bonham-ch.conf was modified to
<VirtualHost *:80>
RewriteEngine on
RewriteCond %{SERVER_NAME} =bonham.ch [OR]
RewriteCond %{SERVER_NAME} =www.bonham.ch
</VirtualHost>
<VirtualHost *:80>
RewriteEngine on
RewriteCond %{SERVER_NAME} =cloud.bonham.ch
</VirtualHost>
The 3 urls above now re-route properly to https, but I get "this site can't be reached" ERR_ADDRESS_UNREACHABLE (chrome) or "Unable to connect" (firefox).
I added
<VirtualHost *:443>
</VirtualHost>
<VirtualHost *:443>
</VirtualHost>
To bonham-ch.conf, and I added 443 to port forwarding on my home router, but I'm still getting the same response.
I'm quite a newb on this stuff, so no consideration is too stupid, any help would be appreciated!
PS I read through this thread and some other threads here with similar problems, but didn't immediately see a relationship. bonham.ch - Make your website better - DNS, redirects, mixed content, certificates gives:
My domain is: bonham.ch
certbot --apache -d cloud.bonham.ch
certbot --apache -d bonham.ch -d www.bonham.ch
certbot output (success)
$ certbot --apache -d cloud.bonham.ch
ssl_module is statically linked but --apache-bin is missing; not disabling session tickets.
Requesting a certificate for cloud.bonham.ch
Certificate is saved at: /etc/letsencrypt/live/cloud.bonham.ch/fullchain.pem
Key is saved at:         /etc/letsencrypt/live/cloud.bonham.ch/privkey.pem
This certificate expires on 2024-04-11.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for cloud.bonham.ch to /etc/apache2/vhosts.d/bonham-ch-le-ssl.conf
Congratulations! You have successfully enabled HTTPS on https://cloud.bonham.ch
 * Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
 * Donating to EFF:                    https://eff.org/donate-le
$ certbot --apache -d bonham.ch -d www.bonham.ch
Requesting a certificate for bonham.ch and www.bonham.ch
Certificate is saved at: /etc/letsencrypt/live/bonham.ch-0001/fullchain.pem
Key is saved at:         /etc/letsencrypt/live/bonham.ch-0001/privkey.pem
Successfully deployed certificate for bonham.ch to /etc/apache2/vhosts.d/bonham-ch-le-ssl.conf
Successfully deployed certificate for www.bonham.ch to /etc/apache2/vhosts.d/bonham-ch-le-ssl.conf
Congratulations! You have successfully enabled HTTPS on https://bonham.ch and https://www.bonham.ch
My web server is (include version): Apache2
$ apachectl -v
Server version: Apache/2.4.58 (Linux/SUSE)
Server built:   2023-10-19 14:26:31.000000000 +0000
$ cat /etc/os-release
NAME="openSUSE Tumbleweed"
# VERSION="20240109"
My hosting provider, if applicable, is: None (home laptop)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.8.0
Welcome to the community @kescobo
And, thanks for thorough report.
I hope the answer will be simple. Looks like something is blocking port 443 on your end. I know you said you opened it but is there a firewall setting in your router that might be blocking it?
"filtered" usually means firewall blocking
nmap -p22,80,443 www.bonham.ch
rDNS record for 108.20.147.223: pool-108-20-147-223.bstnma.fios.verizon.net
PORT    STATE    SERVICE
22/tcp  open     ssh
80/tcp  open     http
443/tcp filtered https
You might also check that Apache is listening on port 443
I think this works on suse
sudo ss -pant | grep -i listen | grep -Ei ':80|:443|httpd|apache'
Could be! I'm using google wifi mesh, and the server is hooked up via ethernet cable to one of the mesh stations, in case that's relevant. Here's what it looks like in the app:
(wasn't sure if sharng MAC address is security issue so I blurred them, but they're identical).
Neither ssh nor http connections worked without these port forwards set, and now they do, so I gather this is doing something. A bit of googling didn't reveal anything else obviously related to a firewall.
There wouldn't be anything relevant on the ISP's modem would there (I'm on FIOS)?
This gives me
ISTEN 0      4096               *:80                  *:*     users:(("httpd-prefork",pid=20010,fd=4),("httpd-prefork",pid=18003,fd=4),("httpd-prefork",pid=18002,fd=4),("httpd-prefork",pid=18001,fd=4),("httpd-prefork",pid=16686,fd=4),("httpd-prefork",pid=16663,fd=4),("httpd-prefork",pid=16621,fd=4),("httpd-prefork",pid=16620,fd=4),("httpd-prefork",pid=16618,fd=4),("httpd-prefork",pid=16617,fd=4),("httpd-prefork",pid=16601,fd=4))
LISTEN 0      4096               *:443                 *:*     users:(("httpd-prefork",pid=20010,fd=6),("httpd-prefork",pid=18003,fd=6),("httpd-prefork",pid=18002,fd=6),("httpd-prefork",pid=18001,fd=6),("httpd-prefork",pid=16686,fd=6),("httpd-prefork",pid=16663,fd=6),("httpd-prefork",pid=16621,fd=6),("httpd-prefork",pid=16620,fd=6),("httpd-prefork",pid=16618,fd=6),("httpd-prefork",pid=16617,fd=6),("httpd-prefork",pid=16601,fd=6))
i
You have to inspect each piece. Sometimes ISP's block port 80 and 443 for residential accounts. It would be odd to block 443 and not 80 but who knows. Worth asking them.
Otherwise, just follow the wire. I have sometimes plugged a computer into the modem and tested that. Then add each piece of equipment until you find the cause.
The ss command shows Apache is listening so that rules that out anyway. Make sure you have checked your o/s for any firewall (not sure if suse has ufw but any others).
Oh, make sure to test HTTP and HTTPS at each step. Ensure HTTP works at each step to rule out some other problem.
This is what I see:
Host is up (0.13s latency).
PORT    STATE    SERVICE
22/tcp  open     ssh
80/tcp  open     http
Hope this helps somewhat.
When you say
Is running this:
Sufficient?
From Internet search, it looks like opensuse uses firewalld, but I certainly haven't interacted with it. Again, seems weird that it would block 443 but not 80 (or 22) for that matter.
Thank you for your prompt responses, I'll probably have to wait until Monday to work on this again, but nice to have an idea of what to look for!
Not trying to interfere here. But I have used openSUSE in the past.
Probably but the test device should be outside your local network. A cell phone with wifi disabled so using the carrier network is an easy way to do that. And, HTTP and HTTPS requests are easily made from browsers just by explicitly stating so in the URL.
here is a cool tool to be run from the source IP:
https://www.grc.com/x/ne.dll?bh0bkyd2
It will show all exposed ports depending on the choices the end user makes.
It's like using an outside source, if one doesn't exist.
Yes, but nmap uses either udp or tcp to determine connectivity. It may be fair test for this particular case but using HTTP / HTTPS directly is more representative.
http/3 apparently uses udp although I do not know it well
I don't see anything relating to http/3 in this thread. (so far)
As far as I can see there's an issue with port 443.
Correct me if I am my normal wrong self... ;@)
No, HTTP/3 is not in play here. I only brought it up to point out that it uses udp whereas HTTP and HTTPS use tcp.
It's really a fine point regarding nmap. It's a fine tool for debugging but it isn't always definitive.
Is this the directly external IP of your home network?:
108.20.147.223
OR
Are you using any type of VPN service?
Are there any systems along the way that might be able to do anything like?: GeoLocation blocking, IP blocking, IPS filtering, Fail2Ban, etc.
So, it was indeed OS-level firewalld setting. I just had to run
sudo firewall-cmd --permanent --zone=public --add-port=443/tcp
as suggested in the link from @Rip
