Site occasionally inaccessible after installing/enabling Certbot [AWS EC2]
My domain is: thecollegecheerguides.com
I ran this command: Trying to access the website itself
It produced this output: 'This site can't be reached. The connection was reset.' However, this only happens most of the time. The site is occasionally accessible.
My web server is (include version): Apache 2.4.52
The operating system my web server runs on is (include version): Ubuntu 22.04.1 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21.0
Hello,
I've created a site hosted on an AWS EC2 instance running Apache2 web server. I installed Certbot and enabled SSL for my website following the Certbot installation settings. The site is only occasionally accessible and usually experiences an SSL error. I've tried many things like ensuring ports 80/443 are open on the instance and within security group in AWS, configuring VirtualHost correctly, re-installing certificates, and more. Any help would be very appreciated. Thanks!
Hello @ep4, welcome to the Let's Encrypt community. :slightly_smiling_face:
I find this odd; this cannot find the certificate being served https://decoder.link/sslchecker/thecollegecheerguides.com/443
"Handshake failed, we haven't received any certificates from the requested server. "
Ah, there are 2 IP Addresses serving that domain name. SSL Server Test: thecollegecheerguides.com (Powered by Qualys SSL Labs) shows both of them. IPv4 34.102.136.180 has issues, where IPv4 44.210.8.113 seems fine.
As shown here
Since you mentioned AWS EC2, my guess for a quick fix it is to leave in DNS the A Record for
44.210.8.113
ec2-44-210-8-113.compute-1.amazonaws.com
And remove the DNS A Record for
34.102.136.180
180.136.102.34.bc.googleusercontent.com
Hi @Bruce5051 , thanks for the quick reply!
I was only aware of the record for 44.210.8.113 but I checked back on my records and, sure enough, there was second type A there. I believe it was used for domain parking, but I removed it. It seems to be working now, but I'll reply back here if I have the issue again. Thank you very much for your help!
These are looking good now
You are very welcome @ep4; have a pleasant rest of your day. :slight_smile:
Yep everything looks great. You have a nice day as well! @Bruce5051
