Hi rg305, thank you for help. Here is my /etc/apache2/sites-enabled/000-default.conf
Sorry. I still hide my domain name.
WSGIDaemonProcess flaskapp threads=5
WSGIScriptAlias / /var/www/html/flaskapp/flaskapp.wsgi
<Directory flaskapp>
WSGIProcessGroup flaskapp
WSGIApplicationGroup %{GLOBAL}
Order deny,allow
Allow from all
</Directory>
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
ServerName www.---.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.---.com
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Here is my /etc/apache2/sites-enabled/000-default-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
# modules, e.g.
SSLCertificateFile /etc/letsencrypt/live/www.---.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.---.com/privkey.pem
</VirtualHost>
</IfModule>
If you are not going to use IPv6 then yes, that could “fix” the problem.
(although it isn’t really a fix at all - more like a “workaround” the problem)
If you are going to use IPv6, then that just shifts the problem to a later date.
I’ve used this method successfully on Ubuntu 16.04:
Putting the following lines in /etc/sysctl.conf: net.ipv6.conf.all.disable_ipv6 = 1 net.ipv6.conf.default.disable_ipv6 = 1 net.ipv6.conf.lo.disable_ipv6 = 1
then sysctl -p
$ netstat -pant | grep -i LISTEN
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 :::443 :::* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
