Site occasionally inaccessible after installing Certbot [AWS EC2]
My domain is: MuslimGPT
I ran this command: Trying to access the website itself
It produced this output: 'This site can't be reached. The connection was reset.' However, this only happens most of the time. The site is occasionally accessible.
My web server is (include version): Apache 2.4.52
The operating system my web server runs on is (include version): Ubuntu 22.04.1 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):1.21.0
Hmm. I am able to connect to your domain consistently but see an nginx server. Can you explain why I see nginx?
curl -i -m10 https://speakrapps.com
HTTP/1.1 404 NOT FOUND
Server: nginx/1.18.0 (Ubuntu)
yes sorry is nginx not apache
Are you still having occasional problems?
When I first tried your URL I failed but now I get through every time. Well, sort of, I get this strange message
curl -i -m10 https://speakrapps.com/muslimgpt/
HTTP/1.1 200 OK
Vous avez été bloquer par le service du FBI. Désactiver votre
VPN/Proxy/TOR/Relay et réessayer. 667.
Google translate says this in English
You have been blocked by the FBI. Disable your
VPN/Proxy/TOR/Relay and try again. 667.
I am not using any of those things. I am using an AWS EC2 test server on the normal AWS network.
Maybe you have some security device blocking your access. I don't see anything wrong with your Let's Encrypt certificate or HTTPS connection.
Well, that's a joke!
The [US] FBI has no such international jurisdiction.
I smell a [fake] MITM.
