Https site not loading
t.mcmotor.ps
sudo certbot --nginx -d t.mcmotor.ps
nginx/1.14.0
ububtu 18.04
no
0.31.0
In addition nginx config file as follow
listen 0.0.0.0:80;
listen 0.0.0.0:443 ssl default;
server_name t.mcmotor.ps;
access_log /var/log/nginx/autoapp_t_access.log;
error_log /var/log/nginx/autoapp_t_error.log;
access_log /var/log/nginx/auto_t_debug.log;
    gzip            on;
    gzip_min_length 1000;
    gzip_comp_level 9;
    #gzip_proxied    expired no-cache no-store private auth;
    gzip_proxied    any;
    gzip_types      text/plain application/json;
            root /var/www/autoapp_t;
            index index.html index.htm;
ssl_certificate /etc/letsencrypt/live/t.mcmotor.ps/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/t.mcmotor.ps/privkey.pem; # managed by Certbot
Hi @mcm
there is a check of your domain, 30 minutes old - https://check-your-website.server-daten.de/?q=t.mcmotor.ps#ct-logs
Certificate creation has worked.
Let's Encrypt Authority X3 2019-08-28 2019-11-26 t.mcmotor.ps
1 entries duplicate nr. 1
http works, https not:
http://t.mcmotor.ps/
185.241.7.215 301 https://t.mcmotor.ps/ 0.140 A
http://www.t.mcmotor.ps/
185.241.7.215 200 0.143 H
185.241.7.215 -14 10.017 T
Timeout - The operation has timed out
https://www.t.mcmotor.ps/
Works your nginx internal?
curl https://t.mcmotor.ps/
from your server?
If yes, it's a firewall problem.
If not, what says
nginx -T
Thank you for reply
is it a firewall problem?
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to t.mcmotor.ps:443
Looks more like a wrong configuration. A regular http output is expected, that's a curl error message.
Is this
a wrong copy? Or is it a listen 443 in the listen 80 block?
I didn’t understand your question
The result of NGINX -T available on
http://t.mcmotor.ps/mcmNginx.conf
