Site does not encrypt unless I key in https://
When user enters url exoplanetary.systems in URL, my site is not encrypted (connection is not secure)
when user enters url https://exoplanetary.systems, my site is encrypted (secure connecton)
This happens for any browser, any os.
On Eapps ispmanager console:
Name is exoplanetary.systems
Aliasses are: *.exoplanetary.systems www.exoplanetary.systems
Need to get secure no matter how a user navigates to page.
My domain is: exoplanetary.systems
I ran this command: (in browser)
when user enters url exoplanetary.systems, not encrypted
when user enters url https://exoplanetary.systems, is encrypted
It produced this output: not encrypted
My web server is (include version): Apache (don’t know version)
The operating system my web server runs on is (include version): centos (don’t know version)
My hosting provider, if applicable, is: eapps
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): ispmanager
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): no
Hi @joenobel
the site doesn't have redirects http -> https ( https://check-your-website.server-daten.de/?q=exoplanetary.systems ):
http://exoplanetary.systems/
68.169.54.161 200 0.253 H
http://www.exoplanetary.systems/
68.169.54.161 200 0.260 H
https://exoplanetary.systems/
68.169.54.161 200 1.430 I
https://www.exoplanetary.systems/
68.169.54.161 200 1.210 I
If a user types exoplanetary.systems (or same with www), then http is used.
Perhaps add something like
RewriteEngine on
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
in your port 80 vHost.
Then recheck your domain. Browsers cache such redirects, so a browser may show a redirect that isn't defined.
PS: Compare the result with the result of other domains (Grade B or A).
Thank you for the quick turnaround.
ISPmanager at EAPPS has a check button “Redirect HTTP-requests to HTTPS”. I did not know what that meant. I checked it off. And now it works. You solved my problem though not exactly as you instructed. :slight_smile:
