Setting Up Pangolin on DO and I Continue Get ACME Errors
I have been trying to set up my Pangolin sever on DO ever since it crashed a few weeks ago. Every time I spin it up now, I continue get an Unable to obtain ACME certificate for domains error. No matter how I try to set it up, I get the same error and I do not understand. I don't know if I am doing something wrong, or there is something wrong with Let's Encrypt.
My domain is: teamgroth.me
I ran this command: docker log traefik -f
root@pangolin:~# docker logs traefik -f
2026-03-16T19:38:09Z INF Traefik version 3.5.6 built on 2025-11-07T13:47:38Z version=3.5.6
Stats collection is disabled.
Help us improve Traefik by turning this feature on :slight_smile:
More details on: Traefik Data Collection Documentation - Traefik
2026-03-16T19:38:09Z INF Loading plugins... plugins=["badger"]
2026-03-16T19:38:09Z INF Plugins loaded. plugins=["badger"]
2026-03-16T19:38:09Z INF Starting provider aggregator *aggregator.ProviderAggregator
2026-03-16T19:38:09Z INF Starting provider *file.Provider
2026-03-16T19:38:09Z INF Starting provider *traefik.Provider
2026-03-16T19:38:09Z INF Starting provider *acme.ChallengeTLSALPN
2026-03-16T19:38:09Z INF Starting provider *acme.Provider
2026-03-16T19:38:09Z INF Testing certificate renew... acmeCA=https://acme-v02.api.letsencrypt.org/directory providerName=letsencrypt.acme
2026-03-16T19:38:09Z INF Starting provider *http.Provider
2026-03-16T19:38:11Z INF Register... providerName=letsencrypt.acme
2026-03-16T19:38:30Z ERR Unable to obtain ACME certificate for domains error="unable to generate a certificate for the domains [pangolin.teamgroth.me]: error: one or more domains had a problem:\n[pangolin.teamgroth.me] invalid authorization: acme: error: 400 :: urn:ietf:params:acme:error:connection :: 159.203.86.149: Fetching http://pangolin.teamgroth.me/.well-known/acme-challenge/lcs86XmolJi_q6eexbqzhEFZM8CSbDAZouwshiWlhyA: Timeout during connect (likely firewall problem)\n" ACME CA=https://acme-v02.api.letsencrypt.org/directory acmeCA=https://acme-v02.api.letsencrypt.org/directory domains=["pangolin.teamgroth.me"] providerName=letsencrypt.acme routerName=ws-router@file rule=Host(pangolin.teamgroth.me)
The operating system my web server runs on is (include version): Ubuntu 24.04 LTS
My hosting provider, if applicable, is: Digital Ocean
In order to verify that you own a domain Let's Encrypt needs to be able to connect to TCP port 80 (HTTP), have you checked your firewall to see whether you're allowing HTTP?
Yes port 80 is open on the firewall for the vps.
Then check all other settings for connections. HTTP requests on port 80 are not able to reach your server. Can you reach your domain from the public internet?
This is a good test site when setting up new systems:
