404 Error Obtaining a Certificate with Traefik Running on Docker
randomparity.com
sudo docker run -d --restart unless-stopped -v /var/run/docker.sock:/var/run/docker.sock -v /var/data/traefik/traefik.toml:/traefik.toml -v /var/data/traefik/acme.json:/acme.json -p 80:80 -p 443:443 -l traefik.frontend.rule=Host:randomparity.com -l traefik.port=8080 --network proxy --name traefik traefik:latest --docker
time="2018-07-09T07:14:52Z" level=error msg="Unable to obtain ACME certificate for domains \"randomparity.com\" detected thanks to rule \"Host:randomparity.com\" : cannot obtain certificates: acme: Error -> One or more domains had a problem:\n[randomparity.com] acme: Error 403 - urn:ietf:params:acme:error:unauthorized - Invalid response from http://randomparity.com/.well-known/acme-challenge/6X5LRG6Pi2XPtOHqFOA9wL9BSLp_mAmxeR4z9wfsFvg: \"<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p\"\n"
Traefik (v1.6.4) running in a Docker (v18.03.1-ce, build 9ee9f40) container.
traefik.toml:
defaultEntryPoints = ["http", "https"]
[web]
address = ":8080"
  [web.auth.basic]
  users = ["admin:XXXXXXXXXXXXXXXXXXXXXXXXXXX"]
[entryPoints]
  [entryPoints.http]
  address = ":80"
    [entryPoints.http.redirect]
      entryPoint = "https"
  [entryPoints.https]
  address = ":443"
    [entryPoints.https.tls]
[acme]
email = "user@example.com"
storage = "acme.json"
onHostRule = true
onDemand = false
[acme.httpChallenge]
entryPoint = "http"
delayBeforeCheck = 0
Ubuntu 18.04
Frontier
Yes
No
Your domain’s IP address appears to be served by web servers related to your QNAP device rather than Traefik.
If the domain is not actually pointing at Traefik in a way that is accessible from the internet, then Let’s Encrypt validation is going to fail.
Thanks for the catch. My NAS was using UPnP to create port forwards that overrode the static port forwarding setup of the gateway which I couldn’t see when testing from inside the network.
Dave
