Not able to get certs
basecrypt.com
Running traefik behind aws elb
time="2018-10-24T16:48:34Z" level=info msg="legolog: [INFO] [basecrypt.com] The server validated our request"
time="2018-10-24T16:48:34Z" level=info msg="legolog: [INFO] [docker.basecrypt.com] acme: Trying to solve HTTP-01"
time="2018-10-24T16:48:34Z" level=error msg="Error getting challenge for token retrying in 5.494505519s"
and also this
time="2018-10-24T16:51:03Z" level=error msg="Unable to obtain ACME certificate for domains \"basecrypt.com,npm.basecrypt.com,git.basecrypt.com,docker.basecrypt.com,dockerhub.basecrypt.com,drone.basecrypt.com\" : unable to generate a certificate for the domains [basecrypt.com npm.basecrypt.com git.basecrypt.com docker.basecrypt.com dockerhub.basecrypt.com drone.basecrypt.com]: acme: Error -> One or more domains had a problem:\n[docker.basecrypt.com] acme: Error 400 - urn:ietf:params:acme:error:connection - Fetching http://docker.basecrypt.com/.well-known/acme-challenge/4QFcu0Jb-Oa1LVOdTFuEoX6jXCCkgUGCBoDfThZyOOE: Error getting validation data\n[git.basecrypt.com] acme: Error 500 - urn:ietf:params:acme:error:serverInternal - Remote PerformValidation RPCs failed\n[dockerhub.basecrypt.com] acme: Error 400 - urn:ietf:params:acme:error:connection - Fetching http://dockerhub.basecrypt.com/.well-known/acme-challenge/gzQMTOmrtFB2S5-qtOdXnatkJrXHoRfaKzznGohYMR8: Error getting validation data\n"
time="2018-10-24T16:51:04Z" level=error msg="Error getting challenge for token retrying in 24.929350656s"
time="2018-10-24T16:51:05Z" level=error msg="Error getting challenge for token retrying in 7.9092465s"
traefik 1.7.3
traefik:1.7.3-alpine
AWS
Yes
no
If you want to secure your nodes behind the AWS elb, the best way is to utilize ACM instead of Let’s Encrypt, since ACM is intergrated in AWS automatically.
Thank you
