Secure padlock issue
My domain is: https://www.livechennai.com
My web server is (include version): IIS
The operating system my web server runs on is (include version): windows server 2008 R2
I have installed lets encrypt manually for our site, but secure padlock is not shown though the certificate shows valid. How can we fix this ? Do we have to do any changes from our end?
Please guide us.
Hi @P00rni
there is a check of your domain, ~~30 minutes old - https://check-your-website.server-daten.de/?q=livechennai.com - please read that output.
  • Your certificate has only the www domain name, so your non www is insecure.
  • You use Tls.1.0, that's deprecated. Update to use Tls.1.2.
  • SHA is deprecated. But that's a result using Tls.1.0.
Hi JuergenAuer,
Thanks for your immediate reply! Can you me help me to fix ssl for non www domain, how do I update Tls 1.2. Please guide.
If you are able to create a certificate with the www domain, then you are able to create a certificate with both domain names.
Tls.1.2: Check
there is a tool IISCrypto. Use that to enable Tls.1.2.
