Replacement SSL certificate required
My domain is: https://nraaccountants.co.za
I ran this command: "you should request a replacement certificate from the issuer (Let’s Encrypt)… when trying to update my certificate
My web server is (include version): Litespeed PHP/7.4.32
The operating system my web server runs on is (include version): 64-bit operating system, x64-based processor
My hosting provider, if applicable, is: HostAfrica
I can login to a root shell on my machine (yes or no, or I don't know): i dnt know
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Cpanel 106.0.9
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): not using Certbot
Regards
Nhlanhla
Clearly not, as that isn't a command. But the message seems pretty clear. What did you do to request another cert? What happened when you tried?
cPanel should have an option to get the cert for you.
