Because you are using cPanel, your options are limited.
The best option for cPanel is to use AutoSSL, which is a built-in cPanel feature that gives you free and automatic SSL certificates for all your domains. Unfortunately it looks like Hostgator, your service provider, has turned this off, presumably because they love money and want to sell you SSL certificates instead.
Some options for you:
Use something like ZeroSSL.com or sslforfree.com to manually issue certificates for your domains every 60-90 days (technically easy but inconvenient)
Move to another cPanel webhost that doesn’t disable AutoSSL (a pain to move initially, but then you don’t ever need to worry about SSL).
Try use Certbot or another ACME client from within your cPanel environment (technically this can get complex, and you’re on your own if you run into problems).
Unfortunately, HostGator is the worst offender in terms of Let’s Encrypt compatibility. In addition to requiring this manual process, they also require support intervention to apply certificates, and charge customers a $10 service fee for this. Since Let’s Encrypt certificates are valid for 90 days, it would cost at least $40/year in HostGator support fees. I would strongly recommend changing hosts, and letting HostGator know why you’re leaving them.
If that’s not possible, you’d be better off buying a longer-validity commercial certificate and using that.
