Renewing SSL certificate - "letsencrypt-auto: command not found"
My SSL certificate was working fine, but I think it has expired. Thus I tried renewing the certificate. From what I found, I think I needed to run ' letsencrypt-auto renew '. However, I started getting an error:
I tried $ letsencrypt-auto renew in also this two paths:
  • $ find / -name letsencrypt-auto
    /root/letsencrypt/letsencrypt-auto-source/letsencrypt-auto
I still get error: letsencrypt-auto: command not found -
What am I doing wrong or missing?
P.S: I am using Nginx from Digital Ocean.
More details:
$ cd /root/letsencrypt/letsencrypt-auto-source
you need to run it as
letsencrypt-auto
not
letsencrypt-auto-
For example:
cd /root/letsencrypt/; ./letsencrypt-auto renew
P.S. Was trying to post the above example for at least 15 minutes, seems like something is wrong today with LE forums ... :expressionless:
Thanks a lot. After stopping and running this command, I successfully made it work! Hooray!!
You should actually switch to using certbot.
