Renewall not possible
My domain is: screwcloud.dynpc.net
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/screwcloud.dynpc.net.conf
http-01 challenge for screwcloud.dynpc.net
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/screwcloud.dynpc.net.conf produced an unexpected error: Failed authorization procedure. screwcloud.dynpc.net (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://screwcloud.dynpc.net/.well-known/acme-challenge/7BW9EU1HT46-GNeGsxy2jYDcgmfdLNMsiou1GPtDh5U: “\r\n403 Forbidden\r\n<body bgcolor=“white”>\r\n
403 Forbidden
\r\n
”. Skipping.
/etc/letsencrypt/live/screwcloud.dynpc.net/fullchain.pem (failure)
nginx version: nginx/1.10.3
Raspbian GNU/Linux 9 \n \l
anydns
Please also provide the contents of /var/log/letsencrypt/letsencrypt.log.
Hi @DocMo
checking your domain ( https://check-your-website.server-daten.de/?q=screwcloud.dynpc.net ):
87.178.20.132 301 https://screwcloud.dynpc.net/ 0.110 A
87.178.20.132 302 Login – Screwcloud 7.500 N
Certificate error: RemoteCertificateChainErrors
Login – Screwcloud 200 3.364 N
http://screwcloud.dynpc.net/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
87.178.20.132 301 https://screwcloud.dynpc.net/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.043 A
https://screwcloud.dynpc.net/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 403 1.907 N
Forbidden
You have a redirect http -> https, this isn't a problem. Same with the expired certificate, Letsencrypt ignores this error.
But you have a real http status code 403 - Forbidden. 404 - not found - was expected.
So your configuration must allow to load a file via /.well-known/acme-challenge.
Create a file (file name 1234) in this subdirectory and test, if you can load this file with your browser.
