Renewal does not work
[edit : after like 10 minutes it started to work, can someone explain me why ??? ]
I keep having issues with a perfectly good ceritficate
https://www.carrefourclubforyou.beneficio.be/ gives SEC_ERROR_UNKNOWN_ISSUER
I first use --cert-test then once it’s ok I go for the real one with a --force-renewal
dont know if it’s the correct way so far …
sudo certbot certonly -n --webroot -d www.carrefourclubforyou.beneficio.be -w /var/www/html/beneficio/carrefourclubforyou --cert-path /etc/letsencrypt/live/www.carrefourclubforyou.beneficio.be/ --key-path /etc/letsencrypt/live/www.carrefourclubforyou.beneficio.be --force-renewal
Renewal conf file /etc/letsencrypt/renewal/notifications.edenred.be.conf is broken. Skipping.
http-01 challenge for www.carrefourclubforyou.beneficio.be
Using the webroot path /var/www/html/beneficio/carrefourclubforyou for all unmatched domains.
Generating key (2048 bits): /etc/letsencrypt/keys/0008_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0008_csr-certbot.pem
 - Congratulations! Your certificate and chain have been saved at
   /etc/letsencrypt/live/www.carrefourclubforyou.beneficio.be/fullchain.pem.
   Your cert will expire on 2017-08-09. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot
   again. To non-interactively renew *all* of your certificates, run
   "certbot renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
here is the apache config
  <VirtualHost *:443>
                ServerName www.carrefourclubforyou.beneficio.be
                DocumentRoot /................
                SSLEngine on
                SSLCertificateFile    /etc/letsencrypt/live/www.carrefourclubforyou.beneficio.be/fullchain.pem
                SSLCertificateKeyFile /etc/letsencrypt/live/www.carrefourclubforyou.beneficio.be/privkey.pem
                <FilesMatch "\.(cgi|shtml|phtml|php)$">
                                SSLOptions +StdEnvVars
                </FilesMatch>
                <Directory /usr/lib/cgi-bin>
                                Options -Indexes
                </Directory>
                <Directory "/...................">
                				allow from all
                                Options -Indexes
                </Directory>
                BrowserMatch "MSIE [2-6]" \
                                nokeepalive ssl-unclean-shutdown \
                                downgrade-1.0 force-response-1.0
                # MSIE 7 and newer should be able to use keepalive
                BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
                SSLProtocol all -SSLv2 -SSLv3
                SSLHonorCipherOrder on
                SSLCipherSuite "EECDH+ECDSA+AESGCM EECDH+aRSA+AESGCM EECDH+ECDSA+SHA384 EECDH+ECDSA+SHA256 EECDH+aRSA+SHA384 EECDH+aRSA+SHA256 EECDH+aRSA+RC4 EECDH EDH+aRSA RC4 !aNULL !eNULL !LOW !3DES !MD5 !EXP !PSK !SRP !DSS !RC4"
        </VirtualHost>
thanks
Certificate is fine
If you are wanting further assitance then please spend 5 minuts explaining what you are observing, what other tests you have ran etc.
My feeling is that information provided is not sufficient to advise.
Andrei
I suggested in another thread that if this error recurs you could save a copy of the cert from the browser and then upload it here, so that we could see what cert it was and what the browser might have found objectionable about it.
