Issue works, renewal doesn't (http-01)
My domain is: xx.xx
I ran this command: ./letsencrypt-auto certonly --webroot -d xx.xx
It produced this output: Success
I ran this command: ./letsencrypt-auto --dry-run renew
It produced this output: Failure
My operating system is (include version): Ubuntu 16.04
My web server is (include version): apache2 (latest)
My hosting provider, if applicable, is: local
Output:
1: $$$$$ FIRST COMMAND $$$$$ Issuing works just fine
su@host:/usr/local/letsencrypt# ./letsencrypt-auto certonly --webroot -d xx.xx
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/xx.xx.conf)
What would you like to do?
1: Keep the existing certificate for now
http-01 challenge for xx.xx
Select the webroot for xx.xx:
1: Enter a new webroot
Press 1 [enter] to confirm the selection (press 'c' to cancel): /var/www/xx.xx
Press 1 [enter] to confirm the selection (press 'c' to cancel): 1
Input the webroot for xx.xx: (Enter 'c' to cancel):/var/www/xx.xx
Generating key (2048 bits): /etc/letsencrypt/keys/0002_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0002_csr-certbot.pem
- Congratulations! Your certificate and chain have been saved at
/etc/letsencrypt/live/xx.xx/fullchain.pem. Your cert will
expire on 2017-07-09. To obtain a new or tweaked version of this
certificate in the future, simply run letsencrypt-auto again. To
non-interactively renew *all* of your certificates, run
"letsencrypt-auto renew"
Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
Donating to EFF:                    https://eff.org/donate-le
2: $$$$$ SECOND COMMAND $$$$$ Renewal does not work
su@host:/usr/local/letsencrypt# ./letsencrypt-auto --dry-run renew
Processing /etc/letsencrypt/renewal/xx.xx.conf
Attempting to renew cert from /etc/letsencrypt/renewal/xx.xx.conf produced an unexpected error: Failed authorization procedure. xx.xx (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://xx.xx/.well-known/acme-challenge/vAshSjnqR3b24lwWiemy_IeVBX2wvlDztxchKAKcMVI: "<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML
4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
". Skipping.<TITLE>Not Found</TITLE>
Processing /etc/letsencrypt/renewal/yy.yy.conf
http-01 challenge for yy.yy
Generating key (2048 bits), not saving to file
Creating CSR: not saving to file
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/yy.yy/fullchain.pem
**          (The test certificates below have not been saved.)
The following certs were successfully renewed:
/etc/letsencrypt/live/yy.yy/fullchain.pem (success)
The following certs could not be renewed:
/etc/letsencrypt/live/xx.xx/fullchain.pem (failure)
**          (The test certificates above have not been saved.)
Domain: xx.xx
Type:   unauthorized
Detail: Invalid response from
<HTML><HEAD><TITLE>Not Found</TITLE>
  • No .htaccess
  • Same configuration between yy.yy and xx.xx - Please take a look at yy.yy/.well-known as well - same behavior
  • Forced 443 however the .well-known folders are available on both 443 and 80 which redirects to 443
  • 0755 on .well-known
  • issue occurs with both root and www-data as owners
No idea how to debug this further. Here is the output of the log: ~removed~
Any help would be greatly appreciated!
Thank you very much for your time.
Cheers,
IonutZ
You should check your webservers log file for any error when you try certbots renewal. It should give you the location where it would expect to find the challenge and you should check if it really exists.
BTW: Both your sites provide a HTTPS certificate for vpn.atex.us from COMODO. Not Let’s Encrypt.
I guess I may be having some issues with the fact that I’m running several domains from the same IP :frowning: I’ll look more into it and post back. Thanks for checking!
Hey can you please check again? I fixed NAT in my firewall and I think it’s going through now. Both cert renews passed with success this time! :slight_smile:
Did you change it back again? Because I'm still getting the wrong certificate:
osiris@desktop ~ $ openssl s_client -connect caza.mba:443 -servername caza.mba
CONNECTED(00000003)
depth=3 C = SE, O = AddTrust AB, OU = AddTrust External TTP Network, CN = AddTrust External CA Root
verify return:1
depth=2 C = GB, ST = Greater Manchester, L = Salford, O = COMODO CA Limited, CN = COMODO RSA Certification Authority
verify return:1
depth=1 C = GB, ST = Greater Manchester, L = Salford, O = COMODO CA Limited, CN = COMODO RSA Domain Validation Secure Server CA
verify return:1
depth=0 OU = Domain Control Validated, OU = PositiveSSL, CN = vpn.atex.us
verify return:1
Certificate chain
 0 s:/OU=Domain Control Validated/OU=PositiveSSL/CN=vpn.atex.us
   i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Domain Validation Secure Server CA
 1 s:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Domain Validation Secure Server CA
   i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority
 2 s:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority
   i:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root
(Sorry I’m still getting used to how this works - removed my entry and replied to yours)
Hey! Ya I did, I gotta figure out how to reroute to my vpn. Although this is beyond the scope of this, maybe you have an idea of what I can do. My configuration is as follows:
Internet -> Firewall -> Apache Webserver @ ip x.x.x.10
Internet -> Firewall -> VPN Server @ ip x.x.x.11
Can I use Apache mod_proxy in order to send traffic that goes to vpn.atex.us (request made to Apache Webserver) to the VPN server? (My VPN works over 443 - SSTP)
Does your VPN server use port 80 and 443? Normally, VPN's use a different port, right? Most of the time, NAT isn't a one takes all kind of thing, but you should be able to specify different ports for different hosts.
Ah, that edit clears things up, sneaky :wink: :stuck_out_tongue:
Hey, I’m using SSTP over 443. It’s all TCP over SSL.
I’m guessing this network setup thingy isn’t really something related to Let’s Encrypt unfortunately. You probably have more luck using Google.
Sounds good! Thank you for your help.
How does one close a topic or thank for responses on here by the way?
Looks like you've managed to find the "like" and "mark as solution" buttons. That'll be about it I guess :wink:
