Renew First LetsEncrypt Certificate
Hi Dears,
I generated my first certificate to a site of my software product two days ago. After the task the system informed that the certificate will expire in 2025 february (3 months). But now I received a Lets Encrypt email informing me that this certificate will expire in 19 days. Is it normal?
Thanks,
Roberto
it'd send renewal email if it isn't exact set do domains: adding or removing a domain from new certificate will not considered as renewal unless it's marked as replacement in ARI(new thing that most clients not yet do) can't confirm its expected unless you tell the domain so we can check public certificate logs
I'm sorry. There was a mistake, and the email that I received was about other domain certification and the alert is correct. I apologize you.
Thanks,
Roberto
