pibby
July 31, 2018, 6:41pm
1
My domain is: pibby.com
I ran this command: ./letsencrypt-auto
It produced this output: No issues
My web server is (include version): nginx version: nginx/1.15.2
The operating system my web server runs on is (include version): Ubuntu 14.04.5 LTS
Nginx Config:
server { ## listen for ipv4; this line is default and implied
root /var/www/pibby.com/_site;
index index.html;
# Make site accessible from http://localhost/
server_name pibby.com www.pibby.com;
access_log /var/log/nginx/access.pibby.com.log;
error_log /var/log/nginx/error.pibby.com.log;
listen 443 ssl http2; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/tea.pib.by/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/tea.pib.by/privkey.pem; # managed by Certbot
if ($scheme != "https") {
} # managed by Certbot
# Redirect non-https traffic to https
# if ($scheme != "https") {
# return 301 https://$host$request_uri;
# } # managed by Certbot
if ($host = www.pibby.com) {
if ($host = pibby.com) {
listen 80;
This same config is working fine for another of my domains (pib.by), but I get too many redirects for pibby.com .
https://www.pibby.com/ redirects to https://pibby.com/ but I don’t see that in your nginx configuration - is that configured elsewhere? (I’m wondering if whatever does that redirect might be misconfigured)
pibby
July 31, 2018, 6:51pm
3
I don’t have it anywhere else, the config I posted is the entire config that I have. I would like www.pibby.com to redirect to pibby.com .
Can you try nginx -T to dump the full configuration? Maybe something in one of your other server blocks is interfering.
First, I would test: For each 301 - redirect, add a # to inactivate this command. Three redirects -> three deactivated rows
If there is another domain with exact the same configuration, that should have no effect -> again a loop.
If there is again a loop: Are there other rewrite rules? Or is there a content management system?
If there is no loop - remove one of the #
rg305
July 31, 2018, 7:37pm
6
Do you also have a redirect in an .htaccess file ? ? ?
@rg305 , op is using nginx
pibby
July 31, 2018, 8:11pm
8
pibby
July 31, 2018, 8:21pm
9
This is the full output of nginx -T
user www-data;
worker_processes 4;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 15;
types_hash_max_size 2048;
server_tokens off;
# SSL Settings
ssl_session_cache shared:SSL:50m;
ssl_session_timeout 10m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA';
ssl_prefer_server_ciphers on;
#ssl_buffer_size 8k;
#ssl_session_tickets on;
# Logging Settings
#access_log /var/log/nginx/access.log;
access_log off;
# Gzip Settings
gzip on;
gzip_disable "msie6";
gzip_vary on;
gzip_proxied any;
gzip_comp_level 3;
gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Compress all output labeled with one of the following MIME-types.
gzip_types
application/atom+xml
application/x-javascript
application/json
application/rss+xml
application/vnd.ms-fontobject
application/x-font-ttf
application/x-web-app-manifest+json
application/xhtml+xml
application/xml
font/opentype
image/svg+xml
image/x-icon
text/css
text/plain
text/x-component;
# nginx-naxsi config
# Uncomment it if you installed nginx-naxsi
#include /etc/nginx/naxsi_core.rules;
# nginx-passenger config
# Uncomment it if you installed nginx-passenger
#passenger_root /usr;
#passenger_ruby /usr/bin/ruby;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
pibby
July 31, 2018, 8:22pm
10
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/svg+xml svg svgz;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.oasis.opendocument.graphics odg;
application/vnd.oasis.opendocument.presentation odp;
application/vnd.oasis.opendocument.spreadsheet ods;
application/vnd.oasis.opendocument.text odt;
application/vnd.openxmlformats-officedocument.presentationml.presentation
pptx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
xlsx;
application/vnd.openxmlformats-officedocument.wordprocessingml.document
docx;
application/vnd.wap.wmlc wmlc;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/conf.d/default.conf:
listen 80;
server_name localhost;
#charset koi8-r;
#access_log /var/log/nginx/log/host.access.log main;
root /usr/share/nginx/html;
index index.html index.htm;
#error_page 404 /404.html;
# redirect server error pages to the static page /50x.html
error_page 500 502 503 504 /50x.html;
location = /50x.html {
# proxy the PHP scripts to Apache listening on 127.0.0.1:80
#location ~ \.php$ {
# proxy_pass http://127.0.0.1;
# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
# root html;
# fastcgi_pass 127.0.0.1:9000;
# fastcgi_index index.php;
# fastcgi_param SCRIPT_FILENAME /scripts$fastcgi_script_name;
# include fastcgi_params;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
# configuration file /etc/nginx/sites-enabled/a.pibby.com:
# You may add here your
# server {
# statements for each of your virtual hosts to this file
# http://wiki.nginx.org/Pitfalls
# http://wiki.nginx.org/QuickStart
# http://wiki.nginx.org/Configuration
# Generally, you will want to move this file somewhere, and start with a clean
# file but keep this around for reference. Or just disable in sites-enabled.
root /var/www/a.pibby.com/public_html;
server_name a.pibby.com;
try_files $uri $uri/ =404;
# Uncomment to enable naxsi on this location
# include /etc/nginx/naxsi.rules
# Only for nginx-naxsi used with nginx-naxsi-ui : process denied requests
#location /RequestDenied {
# proxy_pass http://127.0.0.1:8080;
#error_page 500 502 503 504 /50x.html;
#location = /50x.html {
# root /usr/share/nginx/html;
# fastcgi_split_path_info ^(.+\.php)(/.+)$;
# # NOTE: You should have "cgi.fix_pathinfo = 0;" in php.ini
# # With php5-cgi alone:
# # With php5-fpm:
# fastcgi_pass unix:/var/run/php5-fpm.sock;
#location ~ /\.ht {
# deny all;
# another virtual host using mix of IP-, name-, and port-based configuration
#server {
# listen 8000;
# listen somename:8080;
# server_name somename alias another.alias;
# root html;
# index index.html index.htm;
# location / {
# try_files $uri $uri/ =404;
# HTTPS server
#server {
# listen 443;
# server_name localhost;
# root html;
# ssl on;
# ssl_certificate cert.pem;
# ssl_certificate_key cert.key;
# ssl_session_timeout 5m;
# ssl_protocols SSLv3 TLSv1 TLSv1.1 TLSv1.2;
# ssl_ciphers "HIGH:!aNULL:!MD5 or HIGH:!aNULL:!MD5:!3DES";
# ssl_prefer_server_ciphers on;
# location / {
if ($host = a.pibby.com) {
listen 80 default_server;
listen [::]:80 default_server ipv6only=on;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
# configuration file /etc/nginx/sites-enabled/bio.pibby.com:
#listen [::]:80 default ipv6only=on; ## listen for ipv6
root /var/www/bio.pibby.com/public_html;
server_name bio.pibby.com;
# as directory, then fall back to index.html
try_files $uri $uri/ /index.html;
location ~* \.html$ {
expires -1;
# This block will catch static file requests, such as images, css, js
# The ?: prefix is a 'non-capturing' mark, meaning we do not require
# the pattern to be captured into $1 which should help improve performance
location ~* \.(?:ico|css|js|gif|jpe?g|png)$ {
# Some basic cache-control for static files to be sent to the browser
expires 7d;
add_header Pragma public;
add_header Cache-Control "public, must-revalidate, proxy-revalidate";
root /usr/share/nginx/www;
#location ~ /\.ht {
# deny all;
if ($host = bio.pibby.com) {
listen 80;
pibby
July 31, 2018, 8:23pm
11
# configuration file /etc/nginx/sites-enabled/dev.pibby.com:
server_name dev.pibby.com;
return 301 $scheme://pibby.com$request_uri;
if ($host = dev.pibby.com) {
listen 80;
# configuration file /etc/nginx/sites-enabled/fanfic.weallfalter.com:
listen 80; ## listen for ipv4; this line is default and implied
root /var/www/fanfic.weallfalter.com/public_html;
server_name fanfic.weallfalter.com;
proxy_pass http://localhost:9090;
proxy_set_header Host $host;
expires 30d;
# Specify a charset
charset utf-8;
#location ~ /\.ht {
# deny all;
access_log /var/log/nginx/access.fanfic.weallfalter.com.log;
error_log /var/log/nginx/error.fanfic.weallfalter.com.log;
# configuration file /etc/nginx/sites-enabled/frontenddit.weallfalter.com:
root /var/www/frontenddit.weallfalter.com/public_html;
server_name frontenddit.weallfalter.com;
proxy_pass http://localhost:9292;
expires 30d;
# Specify a charset
charset utf-8;
#location ~ /\.ht {
# deny all;
access_log /var/log/nginx/access.frontenddit.weallfalter.com.log;
error_log /var/log/nginx/error.frontenddit.weallfalter.com.log;
# configuration file /etc/nginx/sites-enabled/git.pib.by:
if ($host = git.pib.by) {
listen 80;
# listen on the www host
server_name git.pib.by;
rewrite ^/(.*) https://git.pib.by/$1 permanent;
listen 443 http2;
#listen 443 ssl http2;
#listen [::]:80 default_server ipv6only=on;
root /var/www/git.pib.by/public_html;
#server_name 172.245.57.115;
ssl on;
ssl_session_timeout 1d;
#ssl_session_tickets off;
# openssl dhparam -out dhparam.pem 2048
ssl_dhparam /etc/nginx/dhparam.pem;
ssl_protocols TLSv1.1 TLSv1.2;
ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK';
add_header Strict-Transport-Security max-age=15768000;
ssl_stapling on;
ssl_stapling_verify on;
## verify chain of trust of OCSP response using Root CA and Intermediate certs
#ssl_trusted_certificate /path/to/root_CA_cert_plus_intermediates;
#ssl_trusted_certificate /etc/letsencrypt/live/git.pib.by/chain.pem;
resolver 8.8.8.8 8.8.4.4 valid=86400;
resolver_timeout 10;
charset utf-8;
expires -1;
location ~* \.(?:ico|css|js|gif|jpg|jpeg|png|woff|ttf|svg|eot|mp4)$ {
expires 1M;
add_header Cache-Control public;
add_header Vary Accept-Encoding;
# configuration file /etc/nginx/sites-enabled/git.pibby.com:
root /var/www/git.pibby.com/public_html;
index index.html;
server_name git.pibby.com;
access_log /var/log/nginx/access.git.pibby.com.log;
error_log /var/log/nginx/error.git.pibby.com.log;
if ($host = git.pibby.com) {
listen 80;
# configuration file /etc/nginx/sites-enabled/git.weallfalter.com:
listen 80;
server_name git.weallfalter.com;
# and redirect to the non-www host (declared below)
# return 301 $scheme://weallfalter.com$request_uri;
rewrite ^(.*)$ https://git.weallfalter.com$1 permanent;
listen 443 http2; ## listen for ipv4; this line is default and implied
#listen 443 ssl http2; ## listen for ipv4; this line is default and implied
root /var/www/git.weallfalter.com/public_html;
ssl on;
ssl_certificate /etc/letsencrypt/live/git.weallfalter.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/git.weallfalter.com/privkey.pem;
# modern configuration. tweak to your needs.
#ssl_dhparam /etc/nginx/ssl/dhparams.pem;
# HSTS (ngx_http_headers_module is required) (15768000 seconds = 6 months)
# OCSP Stapling ---
# fetch OCSP records from URL in ssl_certificate and cache them
ssl_stapling on;
expires -1;
expires 7d;
# Specify a charset
charset utf-8;
#location ~ /\.ht {
# deny all;
# configuration file /etc/nginx/sites-enabled/katieharron.com:
root /var/www/katieharron.com/public_html;
index index.html;
server_name katieharron.com www.katieharron.com;
access_log /var/log/nginx/access.katieharron.com.log;
error_log /var/log/nginx/error.katieharron.com.log;
if ($host = www.katieharron.com) {
if ($host = katieharron.com) {
listen 80;
pibby
July 31, 2018, 8:24pm
12
# configuration file /etc/nginx/sites-enabled/milton.pibby.com:
root /var/www/milton.pibby.com/public_html;
server_name milton.pibby.com;
expires -1;
expires 7d;
#location ~ /\.ht {
# deny all;
if ($host = milton.pibby.com) {
listen 80;
# configuration file /etc/nginx/sites-enabled/pib.by:
root /var/www/pib.by/public_html;
index index.html;
server_name pib.by www.pib.by;
access_log /var/log/nginx/access.pib.by.log;
error_log /var/log/nginx/error.pib.by.log;
if ($host = www.pib.by) {
if ($host = pib.by) {
listen 80;
# configuration file /etc/nginx/sites-enabled/pibby.com:
index index.html;
listen 80;
# configuration file /etc/nginx/sites-enabled/tea.pib.by:
if ($host = tea.pib.by) {
listen 80;
server_name tea.pib.by;
# return 301 $scheme://twt.pib.by$request_uri;
#listen 80;
listen 443 http2;
root /var/www/tea.pib.by/public_html;
ssl on;
#ssl_session_cache shared:SSL:10m;
ssl_stapling on;
ssl_trusted_certificate /etc/letsencrypt/live/weallfalter.com/chain.pem;
proxy_pass http://localhost:9696;
charset utf-8;
expires -1;
client_max_body_size 10M; # Allow files up to 10MB
# configuration file /etc/nginx/sites-enabled/test.pibby.com:
root /var/www/test.pibby.com/public_html;
server_name test.pibby.com;
expires -1;
expires 7d;
#location ~ /\.ht {
# deny all;
access_log /var/log/nginx/access.test.pibby.com.log;
error_log /var/log/nginx/error.test.pibby.com.log;
if ($host = test.pibby.com) {
listen 80;
# configuration file /etc/nginx/sites-enabled/twt.pib.by:
if ($host = twt.pib.by) {
listen 80;
server_name twt.pib.by;
#listen 80;
listen 443 http2;
root /var/www/twt.pib.by/public_html;
ssl on;
ssl_stapling on;
proxy_pass http://localhost:9494;
charset utf-8;
expires -1;
expires 1M;
# configuration file /etc/nginx/sites-enabled/weallfalter.com:
listen 80;
server_name weallfalter.com www.weallfalter.com;
rewrite ^(.*)$ https://weallfalter.com$1 permanent;
root /var/www/weallfalter.com/public_html;
server_name weallfalter.com;
ssl on;
ssl_certificate /etc/letsencrypt/live/weallfalter.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/weallfalter.com/privkey.pem;
# OCSP Stapling ---
ssl_stapling on;
expires -1;
expires 30d;
# Specify a charset
charset utf-8;
#location ~ /\.ht {
# deny all;
access_log /var/log/nginx/access.weallfalter.com.log;
error_log /var/log/nginx/error.weallfalter.com.log;
# configuration file /etc/nginx/sites-enabled/work.pibby.com:
root /var/www/work.pibby.com/public_html;
server_name work.pibby.com;
proxy_pass http://localhost:4000;
#auth_basic "Restricted";
#auth_basic_user_file /etc/nginx/.htpasswd;
if ($host = work.pibby.com) {
listen 80;
user www-data;
worker_processes 4;
pid /run/nginx.pid;
events {
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
server_tokens off;
# SSL Settings
# Logging Settings
access_log off;
# Gzip Settings
gzip on;
gzip_vary on;
gzip_proxied any;
gzip_comp_level 3;
gzip_buffers 16 8k;
gzip_types
application/json
application/rss+xml
application/xml
font/opentype
image/svg+xml
image/x-icon
text/css
text/plain
text/x-component;
#mail {
# server {
# protocol pop3;
# proxy on;
# server {
# protocol imap;
# proxy on;
pibby
July 31, 2018, 8:25pm
13
types {
text/css css;
text/xml xml;
image/gif gif;
text/mathml mml;
text/plain txt;
image/png png;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
pptx;
xlsx;
docx;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
video/mp2t ts;
video/mp4 mp4;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-wmv wmv;
listen 80;
#charset koi8-r;
# root html;
#location ~ /\.ht {
# deny all;
# server {
# # With php5-fpm:
#location ~ /\.ht {
# deny all;
#server {
# listen 8000;
# root html;
# location / {
# HTTPS server
#server {
# listen 443;
# root html;
# ssl on;
# location / {
# this file.
expires -1;
expires 7d;
#location ~ /\.ht {
# deny all;
listen 80;
listen 80;
index index.html;
listen 80;
index index.html;
listen 80;
expires -1;
expires 7d;
#location ~ /\.ht {
# deny all;
listen 80;
index index.html;
listen 80;
index index.html;
listen 80;
listen 80;
#listen 80;
#ssl on;
ssl_stapling on;
charset utf-8;
expires -1;
expires -1;
expires 7d;
#location ~ /\.ht {
# deny all;
listen 80;
listen 80;
#listen 80;
listen 443 http2;
#ssl on;
ssl_stapling on;
charset utf-8;
expires -1;
expires 1M;
listen 80;
That's the only thing I can see that looks like it would redirect to pibby.com specifically, as opposed to whatever $host happens to be. I don't see why that server block would be selected, though. Maybe one of the nginx experts here can chime in with some insight...
pibby:
server_name
I don't use nginx. But there are warnings, that the if - statement is difficult.
If Is Evil
How nginx "location if" works
There is a sample, which looks really bad:
Case 4
location /proxy {
set $a 32;
if ($a = 32) {
return 404;
set $a 76;
proxy_pass http://127.0.0.1 :$server_port/$a;
more_set_headers "X-Foo: $a";
location ~ /(\d+) {
echo $1;
Here, ngx_header_more's more_set_headers will also be inherited by the implicit location created by the "if" block. So you will get:
$ curl localhost/proxy
HTTP/1.1 404 Not Found
Server: nginx/0.8.54 (without pool)
Date: Mon, 14 Feb 2011 05:24:00 GMT
Content-Type: text/html
Content-Length: 184
X-Foo: 32
So the return statement doesn't stop the execution -->> add a break after the lines with return 301.
pibby
July 31, 2018, 9:53pm
17
I didn’t add the Ifs, letsencrypt-auto did. Adding a break after the return 301 doesn’t seem to do anything.
rg305
July 31, 2018, 10:59pm
18
There is an "if scheme not https" check inside a "listen 443 ssl" block.
That should never be hit - you should remove it.
Hi @pibby ,
You said you are using nginx/1.15.2 which is the last development version… (if this is a production server you should use the stable version)… anyway, you ran nginx -T and you didn’t receive any error nor warning message:
You are using ssl on; on several server blocks but ssl directive is deprecated in nginx version 1.15.x so you should have several warning messages saying this:
nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/sites-enabled/xxxxxx.conf:xxx
So, or you didn’t copy the entire output of nginx -T or you are not using nginx 1.15.2.
How did you install nginx 1.15.2 on Ubuntu 14.04.5 ?.
I’m really curious about your redirection issues and I tried to reproduce them using the conf you have posted but I can’t reproduce them, it is working fine here. Could you please package the entire nginx directory and upload it somewhere or put it in some of your working domains like milton?
tar zcvf /var/www/milton.pibby.com/public_html/nginx-pibby.tar.gz /etc/nginx/
I’ll check tomorrow, it’s time for bed here.
Cheers,
sahsanu
_az
August 1, 2018, 12:21am
20
IME mainline is safe to use in production, it's not like running from trunk/master.
