Hello All,
My server is sending TOO MANY REDIRECTS I have done a lot of googling and put a lot of hours into it with no improvements. Below are the details. Any help would be appreciated.
My domain is: ron1.simoninfra.win
I ran this command:apt update -y && apt install -y python-certbot-nginx -t stretch-backports && certbot --nginx
My web server is (include version):nginx/1.10.3
The operating system my web server runs on is (include version):Debian 9.5
My hosting provider, if applicable, is:DigitalOcean
I can login to a root shell on my machine (yes or no, or I don’t know):Yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):No
This is my nginx config after LE modified it.
server_name ron1.simoninfra.win;
root /mnt/ramdisk;
index index.html index.htm;
try_files / =404;
location ~ /.well-known {
allow all;
ssl_certificate /etc/letsencrypt/live/ron1.simoninfra.win/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/ron1.simoninfra.win/privkey.pem; # managed by Certbot
if ($host = ron1.simoninfra.win) {
} # managed by Certbot
listen 80;
Hi @simonindia
checking your website ( https://check-your-website.server-daten.de/?q=ron1.simoninfra.win ): Yep, you have a direct loop:
Your https://ron1.simoninfra.win/ redirects to the same address.
Move this to the listen 80 - block. If your https redirects to https, this is the loop.
Thanks @JuergenAuer . Will move the
listen 80;
@JuergenAuer Done that still the same checked using wget and curl. Also checked using chrome still the same. Thank you for doing this.
Osiris
December 31, 2018, 6:12pm
5
Did you reload nginx after the configuration change?
Please share your complete config file.
Guys thanks for spending your valuable time.
@Osiris yes did a restart and Start, Stop. Did a machine reboot too.
@JuergenAuer Here we go. Nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-auth-pam.conf:
load_module modules/ngx_http_auth_pam_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-dav-ext.conf:
load_module modules/ngx_http_dav_ext_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-echo.conf:
load_module modules/ngx_http_echo_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-subs-filter.conf:
load_module modules/ngx_http_subs_filter_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-upstream-fair.conf:
load_module modules/ngx_http_upstream_fair_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/ron1.simoninfra.win:
root /mnt/ramdisk;
try_files / =404;
allow all;
listen 80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
Are there additional config files with redirects?
Is there a .htaccess with a redirect?
No Just nginx. I don’t have any redirects or .htaccess. Even files are just zip files as this is going to used for internal Android App’s
You have a redirect. And you have to find it.
Check the software running there. I don't see that - I see only the redirect.
Well I don't run this with any software there is no PHP or HTML files all this server does is server some simple zip files.
rg305
December 31, 2018, 7:56pm
12
Try showing the complete configuration in use:
nginx -T
Well I have posted it above but sure thanks for your help. I appreciate it.
user www-data;
pid /run/nginx.pid;
events {
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
# SSL Settings
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
#mail {
# server {
# protocol pop3;
# proxy on;
# server {
# protocol imap;
# proxy on;
types {
text/css css;
text/xml xml;
image/gif gif;
text/mathml mml;
text/plain txt;
image/png png;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/webp webp;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
video/mp2t ts;
video/mp4 mp4;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-wmv wmv;
root /mnt/ramdisk;
try_files / =404;
allow all;
listen 80;
# this file.
rg305
December 31, 2018, 8:01pm
14
I would look for a .htaccess file.
Something is redirecting outside of that config.
Thanks. Well that’s the part making no sense there is not a single file in the directory. I have exhausted my thoughts. This is just a fresh machine in DO this to behaves as same as the original Production instance in AWS.
With this configuration nginx will never serve anything except index.html in the server root directory, and the / argument will probably result in a redirect which you see.
The usual try_files configuration to serve static files is:
try_files $uri $uri/ =404;
sigprof:
First Happy new year. Then yes it seems to be the case. I have been using this as base config using a bash script after this the script creates the file it seems to missing the .$uri $uri is try files.
I appreciate your help will ping back after testing it.
cat << EOT >> /etc/nginx/sites-available/$HOSTSERVER
listen 80;
server_name $HOSTSERVER;
root /mnt/ramdisk;
allow all;
EOT
# Symbolic links
ln -s /etc/nginx/sites-available/$HOSTSERVER /etc/nginx/sites-enabled/$HOSTSERVER
service nginx restart
Guys as @sigprof said in the above post that was the issue. It’s been a while since I used bash for scripting I have made a rookie mistake. Will try and contribute to this forum as I’m new here. I love you guys it been a great experience.
Happy new year All.
And big thanks to LE team and community for making this happen . I will try my best to be part of it.
Good day.
system
Closed
January 31, 2019, 9:27am
19
