pibby
August 1, 2018, 6:50pm
21
Hi sahsanu, thanks for your help! I’ve got the nginx directory available for download at https://milton.pibby.com/nginx-pibby.tar.gz
I don’t remember how I installed 1.15.2, I’ve been using that branch in apt for quite some time, though, ever since it started supporting http2.
I’m not getting the nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" warning because I commented out ssl on in all the config files.
All of my other domains are working fine except for pibby.com , my main site.
pibby
August 1, 2018, 6:56pm
22
I removed it, but the redirect loop is still there.
Hi @pibby ,
I’ve installed nginx mainline version 1.15.2 on Ubuntu, I’ve removed all the contents of /etc/nginx/ and I’ve copied all your conf, I’ve created the right paths to the certificates, some dh-param files, added entries on my /etc/hosts pointing your domains to 127.0.0.1 but I did change absolute nothing of your conf and I’m not able to reproduce your looping issue, it is working pretty fine from my side:
$ curl -IkL http://pibby.com
Server: nginx
Date: Wed, 01 Aug 2018 21:54:24 GMT
Content-Type: text/html
Content-Length: 178
HTTP/2 200
server: nginx
date: Wed, 01 Aug 2018 21:54:24 GMT
content-type: text/html
content-length: 6
last-modified: Wed, 01 Aug 2018 21:54:15 GMT
etag: "5b622c07-6"
accept-ranges: bytes
$ curl -IkL http://www.pibby.com
Server: nginx
Date: Wed, 01 Aug 2018 21:54:29 GMT
Content-Length: 178
HTTP/2 200
server: nginx
date: Wed, 01 Aug 2018 21:54:29 GMT
content-length: 6
etag: "5b622c07-6"
So I’ve no idea what is going on… could you please show the output of these commands (as root or using sudo)?.
netstat -ptan | grep -E '(:80 |:443 )'
ps -ef | grep [n]ginx
Cheers,
sahsanu
pibby
August 2, 2018, 2:29pm
24
sudo netstat -ptan | grep -E '(:80 | :443)'
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 7477/nginx -g daemo
tcp 1 0 5.135.188.86:50360 172.245.57.197:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:60630 185.199.110.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:52956 172.64.134.3:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:34902 185.199.110.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:60478 185.199.109.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:50119 172.64.135.3:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:49700 172.245.57.197:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:47701 172.245.57.197:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:58456 185.53.178.7:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:52415 104.24.124.121:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:36126 172.245.57.197:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:50941 104.24.121.121:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:49968 151.139.237.11:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:40801 185.199.111.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:52476 151.139.237.11:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:58132 185.199.111.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:50361 185.199.109.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:38465 151.139.237.11:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:49452 104.24.121.121:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:38117 185.199.108.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:52305 185.199.111.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:35042 104.24.124.121:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:35969 172.245.57.197:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:36124 185.199.110.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:43148 185.199.111.153:80 CLOSE_WAIT 8056/python2.7
tcp 1 0 5.135.188.86:38058 151.139.237.11:80 CLOSE_WAIT 8056/python2.7
tcp6 0 0 :::80 :::* LISTEN 7477/nginx -g daemo
tcp6 1 0 2001:41d0:8:c556::51273 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::44510 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::32910 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::42106 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::34772 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::47728 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::45889 2400:cb00:2048:1::ac:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::36622 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::54840 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::57444 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::35303 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::37061 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::53968 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::38710 2400:cb00:2048:1::ac:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::40384 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::41950 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::46410 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::58627 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
tcp6 1 0 2001:41d0:8:c556::37490 2400:cb00:2048:1::68:80 CLOSE_WAIT 8056/python2.7
sudo ps -ef | grep nginx
root 7477 1 0 Jul31 ? 00:00:00 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
www-data 11096 7477 0 Jul31 ? 00:00:06 nginx: worker process
www-data 11097 7477 0 Jul31 ? 00:00:01 nginx: worker process
www-data 11098 7477 0 Jul31 ? 00:00:00 nginx: worker process
www-data 11099 7477 0 Jul31 ? 00:00:01 nginx: worker process
Hi @pibby ,
Those outputs look fine, I see no reasons for the loop redirection. Maybe you should stop nginx, check that all nginx processes are stopped and start it again or simply restart the whole server, as I said I run out of ideas
Cheers,
sahsanu
pibby
August 2, 2018, 2:37pm
26
I rebooted and it’s working now!! shrug
Thanks for all your help!
Glad this is working fine after a reboot I suppose nginx was not refreshing the conf properly
system
Closed
September 1, 2018, 2:40pm
28
