Python cryptography module not found after certbot install
My domain is: bfinationalarchivemedia.bfi.org.uk
I ran this command: sudo certbot --nginx -d bfinationalarchivemedia.bfi.org.uk -d www.bfinationalarchivemedia.bfi.org.uk
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.40.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 490, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2854, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2445, in load
return self.resolve()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2451, in resolve
module = import(self.module_name, fromlist=['name'], level=0)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 10, in
import josepy as jose
File "/usr/lib/python3/dist-packages/josepy/init.py", line 41, in
from josepy.interfaces import JSONDeSerializable
File "/usr/lib/python3/dist-packages/josepy/interfaces.py", line 7, in
from josepy import errors, util
File "/usr/lib/python3/dist-packages/josepy/util.py", line 7, in
import OpenSSL
File "/usr/lib/python3/dist-packages/OpenSSL/init.py", line 8, in
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 12, in
from cryptography import x509
ModuleNotFoundError: No module named 'cryptography'
nginx version: nginx/1.18.0 (Ubuntu)
built with OpenSSL 1.1.1f 31 Mar 2020
The operating system my web server runs on is (include version): Ubuntu LTS 20.04
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
This is strange. And it sounds like it's an Ubuntu problem, not a certbot one.
Install certbot following the instructions on certbot.eff.org, please.
I removed certbot via apt, and reinstalled using snap, and that fixed the issue - thank you!
I'm now getting a failure of the challenge, but I'll troubleshoot that and raise a separate issue if necessary.
