No module named '_cffi_backend' when running certbot command
My domain is: no domain name yet because currently setting up
sudo certbot --nginx -d sonarqube.dev.xxx.com
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.40.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 490, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2854, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2445, in load
return self.resolve()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2451, in resolve
module = import(self.module_name, fromlist=['name'], level=0)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 10, in
import josepy as jose
File "/usr/lib/python3/dist-packages/josepy/init.py", line 41, in
from josepy.interfaces import JSONDeSerializable
File "/usr/lib/python3/dist-packages/josepy/interfaces.py", line 7, in
from josepy import errors, util
File "/usr/lib/python3/dist-packages/josepy/util.py", line 7, in
import OpenSSL
File "/usr/lib/python3/dist-packages/OpenSSL/init.py", line 8, in
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 12, in
from cryptography import x509
File "/usr/lib/python3/dist-packages/cryptography/x509/init.py", line 8, in
from cryptography.x509.base import (
File "/usr/lib/python3/dist-packages/cryptography/x509/base.py", line 18, in
from cryptography.x509.extensions import Extension, ExtensionType
File "/usr/lib/python3/dist-packages/cryptography/x509/extensions.py", line 20, in
from cryptography.hazmat.primitives import constant_time, serialization
File "/usr/lib/python3/dist-packages/cryptography/hazmat/primitives/constant_time.py", line 11, in
from cryptography.hazmat.bindings._constant_time import lib
ModuleNotFoundError: No module named '_cffi_backend'
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 20.04.4 LTS
Digital Ocean
Yes
No
certbot is already the newest version (0.40.0-1ubuntu0.1).
Perhaps try:
apt-get -y reinstall python3-cffi-backend libffi7 python3-cryptography libssl1.1
I tried this command
sudo apt install python3-pip python3-dev build-essential libssl-dev libffi-dev python3-setuptools
and also your recommendation successfully :
Unpacking python3-cryptography (2.8-3ubuntu0.1) over (2.8-3ubuntu0.1) ...
Setting up libssl1.1:amd64 (1.1.1f-1ubuntu2.13) ...
Setting up python3-cffi-backend (1.14.0-1build1) ...
Setting up python3-cryptography (2.8-3ubuntu0.1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
but certbot command still returns the same error.
Thanks,
~Ram
Maybe I'm just not very patient today...
But I'd just remove that version and try another ACME client.
OR
Switch to the snap version of certbot.
OR
Use pip in a virtual environment.
Didn't ubuntu/canonical invent snap? Seems like as good a reason as any to use certbot from the official snap distro instead of messing with dependencies.
Here's the instructions: Certbot Instructions | Certbot
Once I removed this package like this:
sudo apt-get -y remove python3-cffi-backend
and reinstalled like this:
sudo apt-get -y reinstall python3-cffi-backend libffi7 python3-cryptography libssl1.1
then certbot can be run successfully:
Congratulations! You have successfully enabled HTTPS on
Thank you very much,
~Ram
