Problems renewing certs
My domain is: tontze.com
I ran this command: renew cert from manager
It produced this output: error
My web server is (include version):dont have one
The operating system my web server runs on is (include version): truenas
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 4.1.1
I found this from log (but dont understand what to do): Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
I have few proxyhosts only that i use to get in to truenas apps.
How should i resolve this ?
Thnx !
Your website doesn't work at all.
HTTP port 80 is blocked and cannot be accessed and HTTPS gives some weird error, closing the connection after the ClientHello..
Please make sure your website is working before attempting to get a certificate.
Ah ok, i just needed to make port 80 available for nginx..
PORT    STATE    SERVICE
22/tcp  filtered ssh
80/tcp  filtered http
443/tcp open     https
Open port 80
