Certificate renewal is not happening
My domain is: test.playtoome.com
I ran this command: sudo certbot renew
No renewals were attempted.
My web server is (include version): Tomcat 7.0.68
The operating system my web server runs on is (include version): Ubuntu 16.04.5 LTS
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.26.1
Hi @panurag
there is a certificate:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:test.playtoome.com&lu=cert_search
valide 13.11.2018 - 11.02.2019
What says certbot certificates ? Did you delete config files?
Your domain is completely invisible ( test.playtoome.com - Make your website better - DNS, redirects, mixed content, certificates )
http://test.playtoome.com/
35.154.202.22 -2 1.380 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 35.154.202.22:80
https://test.playtoome.com/
35.154.202.22 -2 1.370 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 35.154.202.22:443
http://test.playtoome.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
35.154.202.22 -2 1.393 V
so you can't use http-01 validation.
If you have used tls-sni-01 validation, this is deprecated.
What happens if you use
sudo certbot -d test.playtoome.com --preferred-challenges http
But you need an open port 80.
How did you create the certificate?
Did you use Certbot?
What command did you use?
Thank you.
The responnse to certbot certificates is:
No certs found.
No config files were deleted.
Please check at the address https://test.playtoome.com:8443.
The output for the command is “sudo certbot -d test.playtoome.com --preferred-challenges http”:
Certbot doesn’t know how to automatically configure the web server on this system. However, it can still get a certificate for you. Please run “certbot certonly” to do so. You’ll need to manually configure your web server to use the resulting certificate.
Port 80 is open.
Regards,
Anurag
Thank you.
I used certbot to create the certificate. The command used was: “sudo certbot certonly”.
Regards,
Anurag
Sorry, I forgot the certonly - parameter.
sudo certbot certonly -d test.playtoome.com --preferred-challenges http
I see, you have checked your 8443 - port ( test.playtoome.com:8443 - Make your website better - DNS, redirects, mixed content, certificates ): But your port 80 doesn't work.
35.154.202.22 -2 1.397 V
35.154.202.22 -2 1.387 V
35.154.202.22 -2 1.377 V
The last row is critical. Looks there is a firewall or something else that blocks active.
Is there a firewall or another server? I don't see headers, because all standard ports are blocked.
Letsencrypt needs the standard port 80 to check your domain, perhaps a redirect to port 443.
I had used the command “sudo certbot certonly --csr request.csr”, not “sudo certbot certonly”.
Regards,
Anurag
At the time of issuing certificates, I had chosen the option to spin up a temporary server.
Thank you, Regards,
Anurag
Then add the -vvv option, so more informations are logged.
And share
/var/log/letsencrypt/letsencrypt.log
When you use the --csr option, certbot renew does not support renewing the certificate.
Can you create a few certificate without using --csr?
The certificate was created successfully.
Thank you, Regards,
Anurag
Yep
https://test.playtoome.com:8443/
has now a new certificate, created today.
