Certificate is not renewing
My domain is:bettercapital.vc
I ran this command:certbot certonly --force-renew -d www.bettercapital.vc
It produced this output: certificate is renewed
My web server is (include version):nginx/1.12.2
The operating system my web server runs on is (include version): centos7
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.27.1
Your certificate and website looked fine in my browser. If you are seeing a unknown certificate or certificate expired issue, you might want to restart your browser to clear cache.
If you are using certbot with certonly, that means the certificate on your web server will not be updated when the file changed. So you’ll need to reload your web server after certificate renewal.
Thank you
