Problem with subdomains
Hello,
I started using letsencrypt in my server.
I have 3 domains:
domain.org -> /var/www/domain
www.domain.org -> /var/www/domain
test.domain.org -> -> /var/www/testdomain
I use cerbot and run the following command:
cerbot --apache -d domain.org -d www.domain.org -d test.domain.org
when I did that, and tried to access domain.org firefoz gives the error: “The website is not configured correctly and it is not secure…”
So I had to delete all le-ssl.conf files and ran:
And the domain.org started working properly, no errors shown in firefox. But now, if I access http://test.domain.org it redirects to https://test.domain.org and intead of using the directory /var/www/testdomain which is the correct for it, it uses /var/www/domain
I then tried
cerbot --apache -d test.domain.org
But the firefox error comes along when I try to access domain.org.
Has anyone any idea what may be happening? Any workaround?
Here is my test.domain.org.conf
<VirtualHost *:80>
        # specifies what hostname must appear in the request's Host: header to
        #ServerName www.example.com
        ServerAdmin something@domain.org
        ServerName test.domain.org
        ServerAlias domain.org
        DocumentRoot /var/www/testdomain
</VirtualHost>
And here is my domain.org-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
        ServerName domain.org
        ServerAlias www.domain.org
        DocumentRoot /var/www/domain
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =domain.org [OR]
# RewriteCond %{SERVER_NAME} =www.domain.org
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
SSLCertificateFile /etc/letsencrypt/live/domain.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/domain.org/privkey.pem
</VirtualHost>
</IfModule>
Many thanks
Your test domain is only bound to port 80.
Your 443 binding needs to include:
“serverAlias test.domain.org
Also, why does it include
15 times?
Certbot bug. It was fixed in 0.22.0.
