(all sub domains)
portal.stcatherines.eu
vle.stcatherines.eu
blogs.stcatherines.eu
Apache 2.4.25
Debian Linux 9
Yes
No
0.38.0
I’m a total newbie in the field. I don’t know where my problem is. All was running fine until I ran certbot again and added a new subdomain. I use this server to host only my subdomains sites.
When i run apachectl -S
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1. Set the ‘ServerName’ directive globally to suppress this message
VirtualHost configuration:
*:443 is a NameVirtualHost
default server blogs.stcatherines.eu (/etc/apache2/sites-enabled/blogs.stcatherines.eu.conf:1)
port 443 namevhost blogs.stcatherines.eu (/etc/apache2/sites-enabled/blogs.stcatherines.eu.conf:1)
port 443 namevhost portal.stcatherines.eu (/etc/apache2/sites-enabled/portal.stcatherines.eu.conf:11)
port 443 namevhost vle.stcatherines.eu (/etc/apache2/sites-enabled/vle.stcatherines.eu-ssl.conf:1)
*:80 is a NameVirtualHost
default server blogs.stcatherines.eu (/etc/apache2/sites-enabled/blogs.stcatherines.eu.conf:10)
port 80 namevhost blogs.stcatherines.eu (/etc/apache2/sites-enabled/blogs.stcatherines.eu.conf:10)
port 80 namevhost portal.stcatherines.eu (/etc/apache2/sites-enabled/portal.stcatherines.eu.conf:1)
port 80 namevhost vle.stcatherines.eu (/etc/apache2/sites-enabled/vle.stcatherines.eu.conf:1)
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/var/log/apache2/error.log”
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“www-data” id=33
Group: name=“www-data” id=33
then use certbot -d portal.stcatherines.eu - Certbot should find the certificate and should ask, if you want to reinstall it -> try to reinstall it, don't create a new certificate
Blockquote certbot -d portal.stcatherines.eu
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/portal.stcatherines.eu.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press 'c' to cancel): An unexpected error occurred:
EOFError
Select the appropriate number [1-2] then [enter] (press 'c' to cancel): Exiting abnormally:
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.28.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1340, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1089, in run
should_get_cert, lineage = _find_cert(config, domains, certname)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 286, in _find_cert
action, lineage = _find_lineage_for_domains_and_certname(config, domains, certname)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 313, in _find_lineage_for_domains_and_certname
return _find_lineage_for_domains(config, domains)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 264, in _find_lineage_for_domains
return _handle_identical_cert_request(config, ident_names_cert)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 217, in _handle_identical_cert_request
default=0, force_interactive=True)
File "/usr/lib/python3/dist-packages/certbot/display/util.py", line 155, in menu
code, selection = self._get_valid_int_ans(len(choices))
File "/usr/lib/python3/dist-packages/certbot/display/util.py", line 418, in _get_valid_int_ans
ans = input_with_timeout(input_msg)
File "/usr/lib/python3/dist-packages/certbot/display/util.py", line 85, in input_with_timeout
raise EOFError
EOFError
EOFError
Could you please guide me how I can give blogs its own certificate like the others?
as soon as i tried this command
certbot -d blogs.stcatherines.eu Saving debug log to /var/log/letsencrypt/letsencrypt.log Certbot doesn't know how to automatically configure the web server on this system. However, it can still get a certificate for you. Please run "certbot certonly" to do so. You'll need to manually configure your web server to use the resulting certificate.
Once again thanks for your guidance. I did recreate the vHost and updated the certificates with the correct domains. It all looks like its working smoothly now.
