Domain: acegames.de
OS: Linux vserver 2.6.32-042stab116.2 + debian-8.0-amd64-owncloud
Web-Server: Apache2 (I use vHosts to point my subdomains to different locations on the server)
Hosting-Provider: Kramer Betriebs GmbH (Prepaid-Hoster.de)
SSH: ssh connection via putty works perfectly (no controlpanels)
vHost info:
default-vhost: acegames.de (/var/www/html/) and its alias www.acegames.de
second-vhost: status.acegames.de (var/www/html/status/)
third-vhost: cloud.acegames.de (/var/www/owncloud/)
The Story behind it:
If i do the following command: certbot-auto --apache -d -acegames.de -d www.acegames.de
Output is: no errors! has been created.
If i test it, the ony-https works for both (acegames.de and www.acegames.de) but chrome outputs, that the certificate that is used here (www.acegames.de) is ony for acegames.de
[There are issues with the site's certificate chain (net::ERR_CERT_COMMON_NAME_INVALID).]
then if i do: certbot-auto --apache -d cloud.acegames.de
i get:
Failed authorization procedure. cloud.acegames.de (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 137.74.140.78:443 for TLS-SNI-01 challenge.
Domain: cloud.acegames.de
Type: connection
Detail: Failed to connect to 137.74.140.78:443 for TLS-SNI-01
challenge
But i have checked the DNS-Records of acegames.de and theres everything right.
if a certificate has already been made for acegames.de it reports, that there already is a cert for acegames.de
And if i do both in one its getting even more crazy:
certbot-auto --apache -d acegames.de -d www.acegames.de -d cloud.acegames.de
or certbot-auto --apache -d acegames.de -d www.acegames.de -d status.acegames.de (doesnt matter which...)
output:
Failed authorization procedure. cloud.acegames.de (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for TLS-SNI-01 challenge. Requested 5f0fbb61f0a40da088bd1ddd42e0a61b.791f2107b9946e40865ec0855b7a1ed0.acme.invalid from 137.74.140.78:443. Received certificate containing 'dummy, 059f15b2f20053caf0b3f4bbe4f69485.d8267e5a91003c860c27163b540acf29.acme.invalid'
Detail: Incorrect validation certificate for TLS-SNI-01 challenge.
Requested
i am really confused.
