Hello,
I have a fresh install of debian buster and apache.
I want to install https before installing softwares.
My subdomain is dolizelec.zelec.homelinux.net.
The redirection seems to be correct as if I call http://dolizelec.zelec.homelinux.net in a navigator, I have the default apache page.
I install certbot with this guide https://certbot.eff.org/lets-encrypt/debianbuster-apache with snap.
The problem come with
root@dolizelec:/etc# certbot --apache
Enter email address (used for urgent renewal and security notices)
(Enter 'c' to cancel): mymailadress
agree in order to register with the ACME server. Do you agree?
(Y)es/(N)o: y
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: y
Account registered.
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter 'c' to cancel): dolizelec.zelec.homelinux.net
Requesting a certificate for dolizelec.zelec.homelinux.net
http-01 challenge for dolizelec.zelec.homelinux.net
Enabled Apache rewrite module
Challenge failed for domain dolizelec.zelec.homelinux.net
Domain: dolizelec.zelec.homelinux.net
Type: connection
Detail: Fetching
http://dolizelec.zelec.homelinux.net/.well-known/acme-challenge/TINcokC_5hkU0X8OVGSLX_ykH70YPqjQdu2o0_f38hc:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
Thanks for help
Benoit
