It' my router web interface.
I'm searching to modify the rules correctly
I mean can you ssh to the router and run something like:
nginx -T | grep 4433
I understand, but I think the problem don't come from nginx but from redirect rules in the router. So I'm searching in pfsense/HAproxy documentation.
HTTP is closed now.
HTTPS connects to "OLD SERVER" (with wrong cert name)
Yes, because I use these parameters for working.
The oldserver is as said my old server, but until I finished my configuration, I use it.
The change in my configuration is I have one server and I use NAT. This work for the moment correctly.
But for lot of reason I will use VMs in a new server. So I couldn't use NAT. I will use subdomain.
And for the moment I have problems to configure them.
And as I have to work sometime, I have to disable my subdomains rules and reuse NAT rules to my oldserver.
Thank
OK I think I understand what you are trying to do.
pfSense can only NAT one external IP to one internal IP.
That is where HAProxy comes in; pfSense sends all HTTP(S) traffic to HAProxy and it can reverse proxy the different URLs to their corresponding VM servers.
It sounds very straight forward.
Where are you having problems?
Are you running the HAProxy on the same system/IP as the pfSense?
Yes, you understand well.
For the moment, I can redirect subdomain with port 80 correctly to the right server.
The problem is with the port 443 which is intercepted by the WEBGUI of pf sense.
I changed the interface port to 4433, but now pfsense redirect queries from 443 to port 443 to himself.
I'm searching why.
If you don't mind me interrupting your work...
[and I don't know all the details nor limitations of your network - so bare with me]
I would suggest that you virtualize everything (including pfSense).
[this provides a clear separation between all devices and their services]
Give everything it's own internal IP (pfSense also gets the external IP on second interface).
Don't have pfSense listening on the outside IP for management (unless you have to).
If pfSense will be doing inbound SSL inspection, then you must terminate all such connections there (first) before passing them on to the HAProxy.
Hello,
I understand, but as I have few time to work on it, I asked the question in a pfsense forum.
It seems to be simple to do that, so if I can find a faster solution
Thanks for suggestion
Benoit
I think I'm right with pfsense.
but I always have the problem.
apachectl -S gives me
root@dolizelec:~# apachectl -S
VirtualHost configuration:
92.188.16.194:80 dolizelec.zelec.homelinux.net (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
and certbot error:
Domain: dolizelec.zelec.homelinux.net
Detail: Invalid response from
http://dolizelec.zelec.homelinux.net/.well-known/acme-challenge/_bWOWkqCKIrs7bOzwJbxGLfmetEfGCG6phCO8q4CqdY
[92.188.16.194]: "\n\n404 Not
Found\n\nNot Found
\n<p"
thanks for your help
Port 80 has the expected result http status 404 - Not Found. So the main things are ok.
What's the content of
Create a file in yourWebroot/.well-known/acme-challenge (file name 1234), load that file via
http://dolizelec.zelec.homelinux.net/.well-known/acme-challenge/1234
if that works, use webroot with that webroot.
PS: Certbot loves separate config files instead of 000-default.conf. Create a file with domainname + .conf as file name, there the port 80 vHost definition.
content of /etc/apache2/sites-enabled/000-default.conf:
# specifies what hostname must appear in the request's Host: header to
ServerName dolizelec.zelec.homelinux.net
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
I create file /var/www/html/.well-known/acme-challenge/1234 as you asks, that works
but as my webroot is /var/www/html, what do you want I change.
As certbot loves separate config files, I create dolizelec.zelec.homelinux.net.conf, a2ensite doli... and reload apache
Thanks
Yes, it works, so you have found your webroot. Use that with webroot instead of --apache
I've always the same problem:
root@dolizelec:/etc# certbot -w /var/www/html/
1: dolizelec.zelec.homelinux.net
Requesting a certificate for dolizelec.zelec.homelinux.net
http-01 challenge for dolizelec.zelec.homelinux.net
Enabled Apache rewrite module
Challenge failed for domain dolizelec.zelec.homelinux.net
http://dolizelec.zelec.homelinux.net/.well-known/acme-challenge/6yW7T9t2y6UMRpZB-XPJQL0Qxv7Him7rKpLJxO6enUs
Found\n\nNot Found
\n<p"
It's strange, 1234 file reply but not the challenge
Please read the documentation, your result is expected.
See the problem there?
certbot certonly --webroot -w /var/www/html/
Sorry, it's late but you're right, and that works correctly now.
I forgot certonly
Thanks for all your help
Benoit
No... you forgot --webroot
I used -w for webroot
certonly isn't relevant. webroot is relevant. Your output told you: Apache was used.
And certonly doesn't install the certificate.
