Problem with SSL on Ubuntu 22.04 with OpenLiteSpeed and Node.js
Hi, some SSL created by Let's Encrypt, on my VPS work, but others not, even after many attempts. i would like why, and how to solve it; it's crazy. DNS are set correctly.
Thank you
My domain work is: loranrix.com
My domains not work = echangesprives.fr, sludinājumi.com (sludinājumi.com )
The operating system my web server runs on is (include version): Ubuntu 22.04 with OpenLiteSpeed and Node.js (with Cloudflare. but without, the same problem)
My hosting provider, if applicable, is: Hostinger
Hi @Loran, and welcome to the LE community forum :slight_smile:
Are different IPs expected [and one with IPv6] ?:
Address: 195.35.56.221
Addresses: 2a02:4780:1d:c7f9:171a:d1b1:e5a3:53a6    <<<< BAD IP (Hostinger)
           195.35.56.221
Also, different "servers":
curl -Ii http://loranrix.com/
HTTP/1.1 302 Found
date: Fri, 11 Oct 2024 17:14:40 GMT
server: LiteSpeed       <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
connection: Keep-Alive
curl -Ii6 http://echangesprives.fr/
Server: hcdn       <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Date: Fri, 11 Oct 2024 17:15:50 GMT
Content-Type: text/html
Content-Length: 795
platform: hostinger
panel: hpanel
content-security-policy: upgrade-insecure-requests
alt-svc: h3=":443"; ma=86400
x-hcdn-request-id: 26d266ba90b0efbc4995531aee6aa7bb-phx-edge4
x-hcdn-cache-status: HIT
curl -Ii4 http://echangesprives.fr/
HTTP/1.1 302 Found
date: Fri, 11 Oct 2024 17:15:55 GMT
curl -Ii http://xn--sludinjumi-zfb.com/
HTTP/1.1 404 Not Found
date: Fri, 11 Oct 2024 19:53:50 GMT
all these 3 domain names have to point to the same IP, my VPS
how can i solve it so?
and why 1 work but 2 not? they all have the same sets for DNS, Cloudflare, etc... so its not logic that 1 work and 2 others not
Update the DNS zone to show the correct IPv4 address (A record) for all names.
If you are not serving content via IPv6, then remove the IPv6 address (AAAA record).
Then, only one has the correct IPs - the others have at least one incorrect IP.
[One has an incorrect IPv6 address that breaks LE; As LE prefers IPv6 (when available)]
Also, I don't see Cloudflare involved.
and the domain loranrix.com, is witch is working good. the 2 others i get problems
i can share my Cloudflare DNS if can help for solve this problem. but i am not sure it will help, because even before i trtied without Cloudflare, and was the same problem
and "sludinajumi.com" is didferent than "sludinājumi.com"
mine is "sludinājumi.com"
Ok, I'll update my previous post.
You don't have to show that - we can ask the Internet for your DNS information.
Please show:
sudo apachectl -t -D DUMP_VHOSTS
command not found
What shows?:
/usr/local/lsws/conf/httpd_config.conf
[make sure you don't post any private information within that file - like usernames/passwords/keys]
Supplemental, see: Issues updating certbot - #6 by MikeMcQ
Edit:
Also echangesprives.fr has potentially some DNS issues see EDNS Compliance Tester
