I ran this command: sudo /opt/bitnami/letsencrypt/lego --tls --email="graeme@nooqgolf.com" --domains="nooqgolf.com" --domains="www.nooqgolf.com" --domains="nooq.solutions" --domains="www.nooq.solutions" --domains="golf.nooq.solutions" --path="/opt/bitnami/letsencrypt" run
2022/06/23 10:47:57 Could not obtain certificates:
error: one or more domains had a problem:
[nooqgolf.com] acme: error: 400 :: urn:ietf:params:acme:error:connection :: 52.95.149.168: Timeout during connect (likely firewall problem)
I have AWS s3 for re-directing the root domain nooqgolf.com to www.nooqgolf.com but it is causing issues trying to renew. I have tried disabling the s3 bucket re-direct but still getting timeouts trying to renew or create new cert.
My web server is (include version): Apache/2.4.51 (Unix)
The operating system my web server runs on is (include version): Debian GNU/Linux 10 (buster).
My hosting provider, if applicable, is: AWS EC2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): lego 4.7.0
Thanks for quick response. Been trying since yesterday, still same issue. No matter if I disable re-direct from s3 or whether it is enabled. Always getting timeouts
--tls is telling Lego to use the TLS-ALPN-01 challenge, which a special protocol negotiated for Let's Encrypt validation purposes.
The problem is that S3 doesn't support this challenge type and the S3→EC2 redirect doesn't work for this challenge type because it's not based on HTTP.
What you will have to use is the HTTP-01 challenge, which you can do by replacing --tls with --http. What --http does is ask Lego to run a local webserver, which should be enough to make things work. You will need to re-enable your S3 redirect first.
Thanks so much for help. You definitely sparked me down the route for solving this.
Managed to remove the s3 routing.
Changed wordpress from www.example.com to example.com
Changed the TLS ssl checking and used DNS checking instead.
Renewal worked !
