Multi host with s3 bucket, renew fail
When renew, I encounter the message below. (fail)
Is there anything I can do to make renew right ?
ps: the s3public is a aws s3 bucket.
Domain: bookapi.booksdev.digipage.info
Detail: Correct zName not found for TLS SNI challenge. Found
'viewer.booksdev.digipage.info, bookapi.booksdev.digipage.info,
static.booksdev.digipage.info, s3public.booksdev.digipage.info,
appapi.booksdev.digipage.info'
Domain: static.booksdev.digipage.info
Domain: appapi.booksdev.digipage.info
Domain: stream.booksdev.digipage.info
Domain: viewer.booksdev.digipage.info
Domain: s3public.booksdev.digipage.info
Detail: Invalid response from
http://s3public.booksdev.digipage.info/.well-known/acme-
challenge/zgUt0hVD9e2K4OcfRdCoLwNUqI_Larx2W_KuzYHJjRQ
[54.240.170.205]: 404
How are you trying to renew ? (i.e. what command are you using )
and if you place a test file in s3public.booksdev.digipage.info/.well-known/acme-
challenge/ can you reach it in a normal browser ?
usage:
./letsencrypt-auto renew
I put file on s3 bucket and looks like it can be accessed.
