Hi all, apologies in advance for opening yet another thread. But I’m getting this (new) error now.
I’m also keen to restart the certificate procedure from scratch as well (I don’t know how) in order to automate the renewal, as I wasn’t able the first time and I have to do it manually every three months, but every time I generate a new problem.
Thanks,
emilio
emiliovanni.com
sudo /opt/bitnami/letsencrypt/scripts/renew-certificate.sh
Unmonitored apache
Syntax OK
/opt/bitnami/apache2/scripts/ctl.sh : httpd stopped
2020/07/11 10:32:17 [INFO] [emiliovanni.com] acme: Trying renewal with -383 hours remaining
2020/07/11 10:32:17 [INFO] [emiliovanni.com, www.emiliovanni.com, private.emiliovanni.com] acme: Obtaining bundled SAN certificate
2020/07/11 10:32:18 [INFO] [emiliovanni.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5584145908
2020/07/11 10:32:18 [INFO] [private.emiliovanni.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5808865123
2020/07/11 10:32:18 [INFO] [www.emiliovanni.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5808901726
2020/07/11 10:32:18 [INFO] [emiliovanni.com] acme: authorization already valid; skipping challenge
2020/07/11 10:32:18 [INFO] [www.emiliovanni.com] acme: authorization already valid; skipping challenge
2020/07/11 10:32:18 [INFO] [private.emiliovanni.com] acme: use tls-alpn-01 solver
2020/07/11 10:32:18 [INFO] [private.emiliovanni.com] acme: Trying to solve TLS-ALPN-01
2020/07/11 10:32:40 [INFO] Skipping deactivating of valid auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5584145908
2020/07/11 10:32:41 [INFO] Skipping deactivating of valid auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5808865123
2020/07/11 10:32:41 [INFO] Deactivating auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5808901726
2020/07/11 10:32:41 [INFO] Unable to deactivate the authorization: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5808901726
2020/07/11 10:32:41 acme: Error -> One or more domains had a problem:
[private.emiliovanni.com] acme: error: 400 :: urn:ietf:params:acme:error:connection :: Timeout during connect (likely firewall problem), url:
Syntax OK
/opt/bitnami/apache2/scripts/ctl.sh : httpd started at port 80
Apache/2.4.18 (Ubuntu)
| Description: | Ubuntu 16.04.6 LTS |
| Release: | 16.04 |
| Codename: | xenial |
AWS, lightsail instance, bitnami stack
I can login to a root shell on my machine :
Yes I can.
No, doing everything by terminal and AWS wed admin (for DNS, etc).
The version of my client is:
certbot 0.31.0
