Problem with renewal using certbot-auto
https://webtools.wheatoncollege.edu/
./certbot-auto renew
Upgrading certbot-auto 0.17.0 to 0.19.0…
Replacing certbot-auto…
Requesting to rerun ./certbot-auto with root privileges…
Creating virtual environment…
Installing Python packages…
Installation succeeded.
Processing /etc/letsencrypt/renewal/webtools.wheatoncollege.edu.conf
http-01 challenge for webtools.wheatoncollege.edu
Waiting for verification…
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/webtools.wheatoncollege.edu/fullchain.pem
/etc/letsencrypt/live/webtools.wheatoncollege.edu/fullchain.pem (success)
Apache 2
AWS Lightsail
Yes
No
I ran the command to renew the Let’s Encrypt certificate
from within the certbot directory. This ran successfully.
However, when I get the cert info from the browser, the expiration date has not changed.
Should I see that change? If yes, what did I do wrong?
It looks like you used the “certonly” command when requesting your certificate originally. That means you need to reload your Apache configuration after you renew. Since you didn’t specify your operating system and I’m not familiar with Lightsail, I can only guess that this means something like sudo service apache2 reload or sudo systemctl reload apache2.
If you want this to happen automatically after each renewal, see the documentation for --deploy-hook here.
Yes, I forget to restart Apache. Have done so now and all is good. Thank you for your reply.
