It's says not yet due for renewal but they are up
My domain is: goravani.com
I ran this command: sudo certbot renew
It produced this output: The following certs are not due for renewal yet:
/etc/letsencrypt/live/goravani.com/fullchain.pem expires on 2021-04-06 (skipped)
No renewals were attempted.
My web server is (include version): Apache 2
The operating system my web server runs on is (include version): Macintosh OS Catalina
My hosting provider, if applicable, is: Myself
Why do you think you need to renew? Your current webserver is using the same certificate as you've shown here which isn't due to expire for approximately 2 months.
I just rebooted my server and now everything is working.. I didn't know Certbot renews by itself I thought I had to run the command.. my site was saying it was insecure.. so the old one ran out and I was still linked to it, the new one wasn't being used.. reboot fixed this, thank you so much.
Certbot is probably regularly being run from cronjob or a systemd timer. However, this sounds like you got your certificate initially with the certonly subcommand. This means your webserver isn't automatically reloaded to use a renewed certificate.
It's possible to add a reload command (which depends on your distribution and webserver used) to certbot which is ran every time a certificate has been renewed succesfully. This command is called --deploy-hook and you can find more information about it in the official certbot documentation.
An alternative to Osiris's completely functional suggestion is:
sudo certbot renew -i apache
This will keep your existing certificate and update your installation method to reload apache after successfully acquiring/renewing your certificate.
If you want to use the method that Osiris suggested, use this:
sudo certbot renew --deploy-hook "sudo apachectl -k graceful"
