[EDIT] I solve the problem. I need to add the charlytown.me A record
When I execute the command to obtain a certificate I obtain this error:
`Failed authorization procedure. charlytown.me (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up A for charlytown.me
Domain: charlytown.me
Type: connection
Detail: DNS problem: SERVFAIL looking up A for charlytown.meTo fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided.`
The command that I used:
./letsencrypt-auto certonly -a webroot --webroot-path=/path... -d www.charlytown.me -d charlytown.me
If I only generate the certificate to www.charlytown.me works correctly, the problem is only with charlytown.me
What’s wrong with the command?
Server: nginx
Thanks!
