I am trying to generate a letsencrypt certificate for kronos.xdi.uevora.pt, and I am constantly getting the "DNS problem: SERVFAIL looking up A" error. All online DNS tools are able to resolve this name with no problems. I don't understand what can be wrong.
The command that I run was:
sudo letsencrypt certonly -a webroot -w /var/www/letsencrypt -d kronos.xdi.uevora.pt
The complete output is:
Failed authorization procedure. kronos.xdi.uevora.pt (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up A for kronos.xdi.uevora.pt
Domain: kronos.xdi.uevora.pt
Type: connection
Detail: DNS problem: SERVFAIL looking up A for kronos.xdi.uevora.pt
I am using Ubuntu 16.04 and running nginx shipped with GitLab.
Can anyone help with this problem? Thanks!
