Here's more info from the logs:
Script stderr:
Stopping web server
Executing /opt/bitnami/ctlscript.sh status varnish
Script exit code: 0
Script output:
Script stderr:
Executing /opt/bitnami/ctlscript.sh stop apache > /dev/null 2> /dev/null
Script exit code: 0
Script output:
Script stderr:
Executing /opt/bitnami/letsencrypt/lego --version
Stopping web server
Script exit code: 0
Script output:
Script stderr:
Script exit code: 0
Script output:
Script stderr:
Script exit code: 0
Script output:
lego version 4.9.0 linux/amd64
Script stderr:
Extracting Lego
Configuring Let's Encrypt certificates
Executing /opt/bitnami/letsencrypt/lego --path /opt/bitnami/letsencrypt --email="MyEmail"$
Script exit code: 1
Script output:
Script stderr:
2024/04/23 06:45:59 Trying to revoke certificate for domain abtus.es
2024/04/23 06:46:00 Error while revoking the certificate for domain abtus.es
acme: error: 400 :: POST :: https://acme-v02.api.letsencrypt.org/acme/revoke-cert :: urn:ietf:$
Error running /opt/bitnami/letsencrypt/lego --path /opt/bitnami/letsencrypt --email="MyEmail$
Executing chown -R bitnami /opt/bitnami/letsencrypt
Script exit code: 0
Script output:
Script stderr:
Executing chown -R bitnami /opt/bitnami/apps/letsencrypt
Script exit code: 0
Script output:
Script stderr:
Executing find /opt/bitnami/apps/letsencrypt -type f -print0 | xargs -0 chmod 664
Script exit code: 0
Script output:
Script stderr:
Executing find /opt/bitnami/apps/letsencrypt -type d -print0 | xargs -0 chmod 775
Script exit code: 0
Script output:
Script stderr:
Restoring web server configuration
[06:47:20] Restoring configuration file /opt/bitnami/apache/conf/httpd.conf from /opt/bitnami/apache/c$
Setting variable diff from diff -uw /opt/bitnami/apache/conf/httpd.conf /opt/bitnami/apache/conf/httpd$
Script exit code: 0
Script output:
Script stderr:
[06:47:20] Restoring configuration file /opt/bitnami/apache/conf/bitnami/bitnami.conf from /opt/bitnam$
Setting variable diff from diff -uw /opt/bitnami/apache/conf/bitnami/bitnami.conf /opt/bitnami/apache/$
Script exit code: 0
Script output:
Script stderr:
[06:47:21] Restoring configuration file /opt/bitnami/apache/conf/bitnami/bitnami-ssl.conf from /opt/bi$
Setting variable diff from diff -uw /opt/bitnami/apache/conf/bitnami/bitnami-ssl.conf /opt/bitnami/apa$
Script exit code: 0
Script output:
Script stderr:
[06:47:22] Restoring configuration file /opt/bitnami/apache/conf/vhosts/wordpress-https-vhost.conf fro$
Setting variable diff from diff -uw /opt/bitnami/apache/conf/vhosts/wordpress-https-vhost.conf /opt/bi$
Script exit code: 0
Script output:
Script stderr:
[06:47:22] Restoring configuration file /opt/bitnami/apache/conf/vhosts/wordpress-vhost.conf from /opt$
Setting variable diff from diff -uw /opt/bitnami/apache/conf/vhosts/wordpress-vhost.conf /opt/bitnami/$
Script exit code: 0
Script output:
Script stderr:
Stopping web server
Script exit code: 0
Script output:
Script stderr:
Executing /opt/bitnami/ctlscript.sh stop > /dev/null 2> /dev/null
Script exit code: 0
Script output:
Script stderr:
Starting web server
Script exit code: 0
Script output:
Executing /opt/bitnami/ctlscript.sh start > /dev/null 2> /dev/null
Script exit code: 0
Script output:
Script stderr:
Exiting with code 0
