Resetting SSL certificate with bncert-tool for apache does not work
My domain is: www.addlogic.io
I ran this command: sudo /opt/bitnami/bncert-tool
2023/02/08 16:26:46 Error while revoking the certificate for domain
www.addlogic.io
acme: error: 403 :: POST ::
https://acme-v02.api.letsencrypt.org/acme/revoke-cert ::
urn:ietf:params:acme:error:unauthorized :: Certificate is expired
My web server is (include version): apache2
Linux wordpress-multisite-1-vm 4.19.0-23-cloud-amd64 #1 SMP Debian 4.19.269-1 (2022-12-20) x86_64 GNU/Linu
GCP
I like to Reset my certificate, since it expired.
So I use the procedure described at
https://docs.bitnami.com/general/how-to/understand-bncert/
at section ' Resetting the certificates'
For step2 'Modify the Web server configuration' I referred to ' Troubleshooting -> Manually revoking an existing certificate -> Apache' from Learn about the Bitnami HTTPS Configuration Tool
The result is that the dummy certificates are used - but running the bncert-tool to set up new certicates refers again to my old expired certifacates and results in the above error:
www.addlogic.io
Welcome to the community @Andreas2
I don't know why bncert docs would have you revoke a cert that has already expired. You cannot revoke an expired cert.
I would just ignore that step and try renewing the cert.
Yeah, this was bugging me over some days - but now got it fixed just after opening this issue.
I solved the problem by additionally erasing the directory /opt/bitnami/letsencrypt.
bncert-tool has an automatic/mandatory step in renewing.
That makes such a situation so annoying.
But I just got it solved by removing manually the directory /opt/bitnami/letsencrypt.
