Problem with certificate renewal
Hi!
I am not sure where to start with this one? I don't usually post to forums preferring to figure the problem out from help online. However, having spent all day on this, I need your help please. Please read below for the outline overview of my problem domain.
webmail.f4g.tech
sudo certbot certonly --apache -d webmail.f4g.tech --dry-run
http-01 challenge for webmail.f4g.tech
Failed authorization procedure. webmail.f4g.tech (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://webmail.f4g.tech/.well-known/acme-challenge/sTXtEJlY784o7_OaoE2CZRKxqeaRms3mlVh5y8kf5dQ [2a01:4f8:c0c:302a::2]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
   Domain: webmail.f4g.tech
   Type:   unauthorized
   Detail: Invalid response from
Server version: Apache/2.4.18 (Ubuntu)
Ubuntu 16.04.3 LTS
no
certbot 0.31.0
Thanks for your time.
Malcolm
Welcome to the Let's Encrypt Community, Malcolm :slightly_smiling_face:
What is the output of this command?
sudo apachectl -S
Please put three backticks above and below the output, like this:
output
Do you have any kind of proxying in front of Apache, that might be what's keeping certbot from figuring out how to modify your Apache configuration to respond to the challenges? The reason I ask is that your server sends a header of Server: Bob's House which is kind of amusing and not what I'd expect for Apache. But if it's actually Apache answering but with some kind of modified Server header then that might not actually be related.
I wondered the same thing, @petercooperjr. I just took it for a custom Server header.
Hi @petercooperjr . Haha! It is indeed a modified server header.
I might need to remove a recently added AAAA DNS record, which is referenced in the error. However, I must say, that the apache vh conf file specifies ipv4:
<VirtualHost 94.130.72.29:443>
Also, I notice this redirect in Roundcube .htaccess:
RewriteRule ^(?!installer|.well-known/|[a-zA-Z0-9]{16})(.?[^.]+) $ - [F]
I take this to mean .well-known is banned?
I saw nothing wrong with your IPv6 (AAAA record) in my testing. As you indicate, I think something is amiss in your apache configuration. Hence the command I mentioned.
Hi @griffin , as per...
VirtualHost configuration:
[2a01:4f8:c0c:302a::2]:80 ip6.f4g.tech (/etc/apache2/sites-enabled/ip6.f4g.tech.conf:1)
94.130.72.29:80        is a NameVirtualHost
         default server trikaya.f4g.tech (/etc/apache2/sites-enabled/trikaya.f4g.tech-le-ssl.conf:2)
         port 80 namevhost trikaya.f4g.tech (/etc/apache2/sites-enabled/trikaya.f4g.tech-le-ssl.conf:2)
                 alias www.trikaya.f4g.tech
         port 80 namevhost webmail.f4g.tech (/etc/apache2/sites-enabled/webmail.f4g.tech-le-ssl.conf:1)
94.130.72.29:443       webmail.f4g.tech (/etc/apache2/sites-enabled/webmail.f4g.tech-le-ssl.conf:8)
*:443                  is a NameVirtualHost
         default server demo.f4g.tech (/etc/apache2/sites-enabled/demo.f4g.tech-le-ssl.conf:2)
         port 443 namevhost demo.f4g.tech (/etc/apache2/sites-enabled/demo.f4g.tech-le-ssl.conf:2)
         port 443 namevhost f4g.tech (/etc/apache2/sites-enabled/f4g-le-ssl.conf:11)
                 alias www.f4g.tech
         port 443 namevhost groundsourcesolutions.co.uk (/etc/apache2/sites-enabled/groundss.co.uk-ssl.conf:1)
                 alias www.groundsourcesolutions.co.uk
         port 443 namevhost cloud.f4g.tech (/etc/apache2/sites-enabled/nextcloud2-le-ssl.conf:2)
         port 443 namevhost trikaya.f4g.tech (/etc/apache2/sites-enabled/trikaya.f4g.tech-le-ssl.conf:14)
         port 443 namevhost waterseekers.co.uk (/etc/apache2/sites-enabled/waterseekers.co.uk-le-ssl.conf:2)
                 alias www.waterseekers.co.uk
*:80                   is a NameVirtualHost
         default server bob.f4g.tech (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost bob.f4g.tech (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost 100.f4g.tech (/etc/apache2/sites-enabled/100.f4g.tech.conf:1)
         port 80 namevhost avatar.net (/etc/apache2/sites-enabled/avatar.net.conf:1)
                 alias www.avatar.net
         port 80 namevhost demo.f4g.tech (/etc/apache2/sites-enabled/demo.f4g.tech.conf:2)
         port 80 namevhost f4g.tech (/etc/apache2/sites-enabled/f4g-le-ssl.conf:3)
                 alias www.f4g.tech
         port 80 namevhost groundsourcesolutions.co.uk (/etc/apache2/sites-enabled/groundsourcesolutions.co.uk.conf:1)
         port 80 namevhost ip6.f4g.tech (/etc/apache2/sites-enabled/ip6.f4g.tech.conf:19)
                 alias ip6.f4g.tech
         port 80 namevhost manchesterroadsurgery.org.uk (/etc/apache2/sites-enabled/manchesterroadsurgery.org.uk.conf:2)
                 alias www.manchesterroadsurgery.org.uk
         port 80 namevhost cloud.f4g.tech (/etc/apache2/sites-enabled/nextcloud2.conf:1)
         port 80 namevhost numerology.f4g.tech (/etc/apache2/sites-enabled/numerology.f4g.tech.conf:1)
                 alias www.numerology.f4g.tech
         port 80 namevhost map.waterseekers.co.uk (/etc/apache2/sites-enabled/waterseekers-map.co.uk.conf:1)
                 alias borehole-map.waterseekers.co.uk
         port 80 namevhost waterseekers.co.uk (/etc/apache2/sites-enabled/waterseekers.co.uk.conf:3)
         port 80 namevhost waterwelldrilling.waterseekers.co.uk (/etc/apache2/sites-enabled/waterwelldrilling.conf:2)
         port 80 namevhost web.f4g.tech (/etc/apache2/sites-enabled/web.f4g.tech.conf:1)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Mutex default: dir="/var/lock/apache2" mechanism=fcntl
Mutex proxy-balancer-shm: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: MODSEC_2.5
Define: MODSEC_2.9
Define: ENABLE_USR_LIB_CGI_BIN
Define: F4G=/var/www/f4g.tech/
User: name="www-data" id=33
Group: name="www-data" id=33
This is what's responding on IPv6 for webmail.f4g.tech.
I think there's probably more in there to address, but let's start with the problem at hand...
What are the contents of these files?
What are the outputs of these commands?
sudo ls -lRa /etc/apache2/sites-available
sudo ls -lRa /etc/apache2/sites-enabled
Please put three backticks above and below each content and output, like this:
content/output
ip6.f4g.tech.conf
<VirtualHost [2a01:4f8:c0c:302a::2]:80>
#<VirtualHost *:80>
   ServerName ip6.f4g.tech
   ServerAlias ip6.f4g.tech
   DocumentRoot /var/www/ip6.f4g.tech/htdocs
#  Alias /bkup /root/bin/backup
#  PHPINIDir  /var/www/repo.f4g.tech/php
</VirtualHost>
<VirtualHost *:80>
</VirtualHost>
<VirtualHost 94.130.72.29:80>
   ServerName webmail.f4g.tech
   Redirect permanent / https://webmail.f4g.tech
</VirtualHost>
<IfModule mod_ssl.c>
DocumentRoot /var/www/_apps/roundcubemail-1.3.4
ServerAdmin admin@f4g.tech
ErrorLog ${APACHE_LOG_DIR}/roundcube-error.log
CustomLog ${APACHE_LOG_DIR}/roundcube-access.log combined
SSLCertificateFile /etc/letsencrypt/live/webmail.f4g.tech/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/webmail.f4g.tech/privkey.pem
</VirtualHost>
<Directory /var/www/_apps/roundcubemail-1.3.4>
#DirectoryIndex index.php
#Options +FollowSymLinks
AllowOverride All
#Require all granted
</Directory>
</IfModule>
Enabled:
lrwxrwxrwx 1 root root   35 Jun  7  2017 000-default.conf -> ../sites-available/000-default.conf
lrwxrwxrwx 1 root root   36 Mar 13 23:15 100.f4g.tech.conf -> ../sites-available/100.f4g.tech.conf
lrwxrwxrwx 1 root root   34 May 31  2019 avatar.net.conf -> ../sites-available/avatar.net.conf
lrwxrwxrwx 1 root root   37 Apr 19 16:59 demo.f4g.tech.conf -> ../sites-available/demo.f4g.tech.conf
lrwxrwxrwx 1 root root   44 Apr 19 16:59 demo.f4g.tech-le-ssl.conf -> ../sites-available/demo.f4g.tech-le-ssl.conf
lrwxrwxrwx 1 root root   34 Apr 19 16:58 f4g-le-ssl.conf -> ../sites-available/f4g-le-ssl.conf
lrwxrwxrwx 1 root root   51 Jun 27  2020 groundsourcesolutions.co.uk.conf -> ../sites-available/groundsourcesolutions.co.uk.conf
-rw-r--r-- 1 root root  792 Sep 24  2020 groundsourcesolutions.co.uk.conf.bkup
lrwxrwxrwx 1 root root   42 Oct  7  2020 groundss.co.uk-ssl.conf -> ../sites-available/groundss.co.uk-ssl.conf
lrwxrwxrwx 1 root root   36 Aug 26  2017 ip6.f4g.tech.conf -> ../sites-available/ip6.f4g.tech.conf
lrwxrwxrwx 1 root root   52 Aug 17  2017 manchesterroadsurgery.org.uk.conf -> ../sites-available/manchesterroadsurgery.org.uk.conf
lrwxrwxrwx 1 root root   34 May 29  2020 mytest.com.conf -> ../sites-available/mytest.com.conf
lrwxrwxrwx 1 root root   34 Nov 20  2017 nextcloud2.conf -> ../sites-available/nextcloud2.conf
lrwxrwxrwx 1 root root   51 Jan 29 03:49 nextcloud2-le-ssl.conf -> /etc/apache2/sites-available/nextcloud2-le-ssl.conf
lrwxrwxrwx 1 root root   43 Feb 16  2020 numerology.f4g.tech.conf -> ../sites-available/numerology.f4g.tech.conf
lrwxrwxrwx 1 root root   57 Mar 20  2020 trikaya.f4g.tech-le-ssl.conf -> /etc/apache2/sites-available/trikaya.f4g.tech-le-ssl.conf
lrwxrwxrwx 1 root root   42 Aug 17  2017 waterseekers.co.uk.conf -> ../sites-available/waterseekers.co.uk.conf
lrwxrwxrwx 1 root root   59 Mar 21  2020 waterseekers.co.uk-le-ssl.conf -> /etc/apache2/sites-available/waterseekers.co.uk-le-ssl.conf
lrwxrwxrwx 1 root root   46 Jan 11  2019 waterseekers-map.co.uk.conf -> ../sites-available/waterseekers-map.co.uk.conf
lrwxrwxrwx 1 root root   41 Aug 17  2017 waterwelldrilling.conf -> ../sites-available/waterwelldrilling.conf
lrwxrwxrwx 1 root root   36 Apr 22  2020 web.f4g.tech.conf -> ../sites-available/web.f4g.tech.conf
lrwxrwxrwx 1 root root   47 Jan 30 20:52 webmail.f4g.tech-le-ssl.conf -> ../sites-available/webmail.f4g.tech-le-ssl.conf
Available
-rw-r--r-- 1 root root      1434 Nov 20  2017 000-default.conf
-rw-r--r-- 1 root root      1332 Jun  7  2017 000-default.conf.bak
-rw-r--r-- 1 root root      2418 Feb 12 23:13 100.f4g.tech.conf
-rw-r--r-- 1 root root       653 May 31  2019 avatar.net.conf
-rw-r--r-- 1 root root      6460 Jun  7  2017 default-ssl.conf
-rw-r--r-- 1 root root      6338 Jun  7  2017 default-ssl.conf.bak
-rw-r--r-- 1 root root       868 Mar 17  2020 demo.f4g.tech.conf
-rw-r--r-- 1 root root       895 Mar 17  2020 demo.f4g.tech-le-ssl.conf
-rw-r--r-- 1 root root       714 Jun 27  2020 dev10.f4g.tech.conf
-rw-r--r-- 1 root root       531 Mar 17  2020 f4g.conf
-rw-r--r-- 1 root root       552 Mar 17  2020 f4g-ip6.conf
-rw-r--r-- 1 root root       878 Feb  2 20:36 f4g-le-ssl.conf
-rw-r--r-- 1 root root      1506 Aug 16  2017 go2.nobug.uk.conf
-rw-r--r-- 1 root root      1451 Mar  9  2018 go.nobug.uk.conf
-rw-r--r-- 1 root root       794 Jan 25 19:07 groundsourcesolutions.co.uk.conf
-rw-r--r-- 1 root root       514 Apr 19 16:50 groundss.co.uk-ssl.conf
-rw-r--r-- 1 root root       559 Feb 17 19:25 ip6.f4g.tech.conf
-rw-r--r-- 1 root root       801 Aug 17  2017 manchesterroadsurgery.org.uk.conf
-rw-r--r-- 1 root root       490 Feb 13  2018 media.energyenhancement.org.conf
-rw-r--r-- 1 root root      1760 Jan 29 03:49 nextcloud2.conf
-rw-r--r-- 1 root root      1959 Jan 29 03:49 nextcloud2-le-ssl.conf
-rw-r--r-- 1 root root      1620 Jun 21  2018 nodejs1.nobug.uk.conf
-rw-r--r-- 1 root root      1496 Feb 16  2020 numerology.f4g.tech.conf
-rw-r--r-- 1 root root       725 Oct 27  2017 rygan.co.uk.conf
-rw-r--r-- 1 root root      1445 Apr 26  2020 too.f4g.tech.conf
-rw-r--r-- 1 root root       664 May  8  2018 trikaya.es.conf
-rw-r--r-- 1 root root       865 Mar 20  2020 trikaya.f4g.tech.conf
-rw-r--r-- 1 root root      1268 Feb 17 19:31 trikaya.f4g.tech-le-ssl.conf
-rw-r--r-- 1 root root      1230 Mar 21  2020 waterseekers.co.uk.conf
-rw-r--r-- 1 root root      2395 Apr 13  2020 waterseekers.co.uk-le-ssl.conf
-rw-r--r-- 1 root root     12288 Apr 12  2020 .waterseekers.co.uk-le-ssl.conf.swp
-rw-r--r-- 1 root root       959 Jan 12  2019 waterseekers-map.co.uk.conf
-rw-r--r-- 1 root root      5311 Aug 17  2017 waterwelldrilling.conf
-rw-r--r-- 1 root root      1445 Apr 22  2020 web.f4g.tech.conf
-rw-r--r-- 1 root root       377 Mar  2  2018 webmail.f4g.tech.conf
-rw-r--r-- 1 root root       762 Apr 19 17:37 webmail.f4g.tech-le-ssl.conf
-rw-r--r-- 1 root root      2418 Sep  4  2019 what.nobug.uk.conf
Thanks for that. :slightly_smiling_face:
It's as I suspected. All of the port 80 named vhost configurations have been disabled, so apache has no idea which vhost to use at times. Let's fix one as a sample.
What are the contents of this file?
/etc/apache2/sites-available/webmail.f4g.tech.conf
<VirtualHost *:80>
  DocumentRoot /var/www/roundcube
  <Directory /var/www/roundcube>
      Options -Indexes
      AllowOverride All
      Order allow,deny
      allow from all
  </Directory>
</VirtualHost>
So, let's do this...
sudo a2dissite webmail.f4g.tech-le-ssl.conf
sudo mkdir /etc/apache2/sites-available/backup
sudo cp /etc/apache2/sites-available/webmail.f4g.tech.conf backup
sudo mv /etc/apache2/sites-available/webmail.f4g.tech-le-ssl.conf backup
Then edit /etc/apache2/sites-available/webmail.f4g.tech.conf with a text editor to make it:
<VirtualHost *:80>
</VirtualHost>
sudo a2ensite webmail.f4g.tech.conf
sudo apachectl -k graceful
At this point, webmail.f4g.tech should respond correctly via http over port 80.
sudo certbot certonly --apache -d "webmail.f4g.tech" --dry-run
If that succeeds, then...
sudo certbot --apache -d "webmail.f4g.tech" --keep
At this point, webmail.f4g.tech should be redirected from http to https over port 80 and should respond correctly via https over port 443.
OK, does it matter that http webmail now displays web content of ip6.f4g.tech?
Thanks
It shouldn't after enabling the new webmail.f4g.tech.conf (unless they point to the same webroot folder, in which case it's expected, but I doubt it will happen).
Well, before I run certbot...
ip6.f4g points to a directory which exists, has html file in it and is different to webmail conf.
webmail.f4g.tech now displays content from this path given in below doc root:
#<VirtualHost *:80>
</VirtualHost>
<VirtualHost *:80>
</VirtualHost>
This is after running all those commands?
If so, what is the current output of this command?
sudo apachectl -S
Yes, I ran up to and including apache -k graceful.
94.130.72.29:80        trikaya.f4g.tech (/etc/apache2/sites-enabled/trikaya.f4g.tech-le-ssl.conf:2)
                 alias www.f4g.tech
                 alias www.f4g.tech
                 alias ip6.f4g.tech
         port 80 namevhost webmail.f4g.tech (/etc/apache2/sites-enabled/webmail.f4g.tech.conf:1)
Define: DUMP_VHOSTS
Define: MODSEC_2.5
Define: MODSEC_2.9
The original http document root for webmail.f4g.tech was this:
/var/www/roundcube
The https document root for webmail.f4g.tech shows as this:
Does this command succeed now though?
