Problem renewing certificates
My domain is: many domains
Processing /etc/letsencrypt/renewal/example.com-0001.conf
Renewing an existing certificate for mail.ends.no and 55 more domains
Domain: cloud.austadmaskin.no
Detail: Invalid response from http://example.com/.well-known/acme-challenge/3BegyUKoDpMiNTNironlRK68EWMtRv4VN0D2AFSYPtY [x.x.x.x]: "\n\n403 Forbidden\n\n
Forbidden
\n<p"
Domain: example.com
Detail: Invalid response from http://example.com/.well-known/acme-challenge/Zmq5D5Gwiqmgi36qDtB11Avxdd5Wv3ORGLEqvT5q72E [x.x.x.x]: "\n\n403 Forbidden\n\n
Forbidden
\n<p"
Failed to renew certificate example.com-0001 with error: Some challenges have failed.
/etc/letsencrypt/live/example.com-0001/fullchain.pem (failure)
Various.
Various.
I can access my certbot by root; yes.
Various.
certbot 1.17.0
I have rebooted my certbot but it did not help.
Latest renewal was a few months ago and it went fine; I do not think anything has changed on the certbot-server since then so Im confused, any help greatly appreciated!
Welcome to the Let's Encrypt Community :slightly_smiling_face:
It looks like your port 80 (http) is returning 403 Forbidden. Upon closer inspection, it appears that the culprit likely lies in either your Apache configuration for port 80 or an .htaccess file. :face_with_monocle:
What is the output of:
sudo apachectl -S
It looks like this certificate was setup to renew using --standalone, but you are already running an Apache server. One would usually use --apache in a case like this, because the standalone authenticator is generally only applicable when you are not already running a webserver.
If you try this, does it renew?
sudo certbot renew --cert-name example.com \
--pre-hook "service apache2 stop" \
--post-hook "service apache2 restart" \
--dry-run
Thank you very much for your replies @griffin and @_az - it is really appreciated.
I am a bit confused, because the certbot says:
So...is it a temporary webserver existing on my certbot-server, or is it the one residing on my Nextcloud server (in this case)?
(this is run on Nextcloud since it will fail with "sudo: apachectl: command not found" if run on Certbot)
root@nc:/var/www# sudo apachectl -S
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 172.16.0.20. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:80 is a NameVirtualHost
default server 192.168.0.20 (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost 192.168.0.20 (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost cloud.redacted.net (/etc/apache2/sites-enabled/nextcloud-redacted.conf:1)
alias sky.redacted.net
port 80 namevhost cloud.ed2.no (/etc/apache2/sites-enabled/nextcloud-ed2.conf:1)
alias sky.ed2.no
alias nc.ed2.no
port 80 namevhost cloud.ed3.no (/etc/apache2/sites-enabled/nextcloud-ed3.conf:1)
alias sky.ed3.no
port 80 namevhost sky.ed4.no (/etc/apache2/sites-enabled/nextcloud-ed4.conf:1)
port 80 namevhost cloud.ed5.no (/etc/apache2/sites-enabled/nextcloud-ed5.conf:1)
alias sky.ed5.no
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
You have new mail in /var/mail/root
and
root@certbot:/etc/letsencrypt# sudo certbot renew --cert-name mail.redacted.net-0001 \
--dry-run
Processing /etc/letsencrypt/renewal/mail.redacted.net-0001.conf
Hook 'pre-hook' reported error code 5
Hook 'pre-hook' ran with error output:
Failed to stop apache2.service: Unit apache2.service not loaded.
Simulating renewal of an existing certificate for mail.redacted.net and 55 more domains
Domain: cloud.redacted.net
Detail: Invalid response from http://cloud.redacted.net/.well-known/acme-challenge/1UrFvxAaDcZFjNW_Rs-lpgS1VE6-NU9l3BAnHF2T_5w [1.2.3.4]: "\n\n403 Forbidden\n\n
Forbidden
\n<p"
Domain: sky.redacted.net
Detail: Invalid response from http://sky.redacted.net/.well-known/acme-challenge/YMi03GgKEFVuAydcZs4Ajui3spoXJGT1lAoMhQkNFL4 [1.2.3.4]: "\n\n403 Forbidden\n\n
Forbidden
\n<p"
Failed to renew certificate mail.redacted.net-0001 with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/mail.redacted.net-0001/fullchain.pem (failure)
Hook 'post-hook' reported error code 5
Hook 'post-hook' ran with error output:
Failed to restart apache2.service: Unit apache2.service not found.
The temporary server is activated on the server where certbot is running. If Nextcloud is on a different server, then this error is to be expected: the Let's Encrypt validation server is connecting to the hostname sky.austadmaskin.no, but if that's running on a different server than certbot, it can't connect to the temporary server spinned up by certbot obviously.
Please read more about how Let's Encrypt works here:
Thanks @Osiris - probably worth mentioning that I've "inherited" this setup and I have not set it up so I'm in the phase of learning everything from the ground up.I am a total newbie when it comes to both certbot, letsencrypt, nextcloud.....much to learn :slight_smile:
Ok, so I investigated a bit more. Theres "Path-specific routing" enabled on the firewall that handles all requests to the two (above) mentioned urls (and many more). If someone is trying to access "/.well-known/acme-challenge/" they will be sent to the cerbot-server, all other requests "/" will be sent to the nextcloud-server, on-prem exchange etc. This rule however is "Listening port: 443"
The communication during renewal are coming to the certbot on port 80 or is it 443?
That depends on the challenge used. Please see the Let's Encrypt documentation:
(It's categorized under " Advanced Subscriber Information" in the documentation page, but in my opinion its part of the basics of understanding how Let's Encrypt works.)
An http-01 challenge starts from a domain name on port 80 (http) then follows up to 10 redirects to domain names on either port 80 (http) or port 443 (https). IPv6 addresses (DNS AAAA records) are given priority over IPv4 addresses (DNS A records) for challenge requests.
Thank you @griffin and @Osiris
I found a "checkbox" on the firewall-rule for the domains that failed earlier named "Redirect HTTP". It was not checked in the firewall-rule. When checked::
root@certbot:/etc/letsencrypt# sudo certbot renew --cert-name mail.redacted.net-0001 --dry-run
Congratulations, all simulated renewals succeeded:
  /etc/letsencrypt/live/mail.redacted.net-0001/fullchain.pem (success)
There are rules for all domains and none of them has the "Redirect HTTP" checked, my guess is that the domains failing above is the first one that is tried, and after this it does not matter whether its 80 or 443(?) as long as the first one goes through...so to speak?
I don't exactly understand your question, but the same requirements independently apply for all domain names being certified via http-01 challenges.
Thank you everyone for your help in this. All my certificates are now renewed. :slightly_smiling_face: :+1:
You are quite welcome. :blush:
@_az - thanks again for suggestion; Could you please redact our DNS from your post now that the problem is solved? Replace the dns with "example.com" or similar?
