Hi!
i have a problem with renewing my existing certificate with certbot.
My domain is: elberthome.dnshome.de.
The Problem says my domain has a problem with the dns a/aaaa-record.
but, the domain results in the right IP-Adress. and, if i check my domain in browser, i am at the right server.
my firewall accepts port 443 and 80 to the raspberry-client.
Thank you in Advance!
certbot renew
Processing /etc/letsencrypt/renewal/elberthome.dnshome.de.conf
http-01 challenge for elberthome.dnshome.de
Waiting for verification…
Attempting to renew cert (elberthome.dnshome.de) from /etc/letsencrypt/renewal/elberthome.dnshome.de.conf produced an unexpected error: Failed authorization procedure. elberthome.dnshome.de (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://elberthome.dnshome.de/.well-known/acme-challenge/sMxcHwbEG45R-5qncd4DwY73jRpvl-ATxzpuJdHmU5o 217.247.45.47: “<html>\r\n<head><title>403 Forbidden</title></head>\r\n<body bgcolor=“white”>\r\n<center><h1>403 Forbidden</h1></center>\r\n<hr><center>”. Skipping.
/etc/letsencrypt/live/elberthome.dnshome.de/fullchain.pem (failure)
Domain: elberthome.dnshome.de
Detail: Invalid response from
Forbidden</h1></center>\r\n<hr><center>"
The operating system my web server runs on is (include version): raspbian v9 “stretch”
I can login to a root shell on my machine (yes or no, or I don’t know): yes! i sent “certbot -renew” from my root shell
or certbot-auto --version
if you’re using Certbot): certbot 0.28.0
