Problem with certbot renewal
Dear all,
I need to renew my certificat for my website, but somehow I run into troubles, here are the answers to the general questions:
My domain is: www.3bij3.nl
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/www.3bij3.nl.conf
http-01 challenge for www.3bij3.nl
http-01 challenge for 3bij3.nl
Waiting for verification…
Attempting to renew cert (www.3bij3.nl) from /etc/letsencrypt/renewal/www.3bij3.nl.conf produced an unexpected error: Failed authorization procedure. www.3bij3.nl (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.3bij3.nl/.well-known/acme-challenge/uJo9XZ_E61EpIw5GjKXJzV2wJVeBVLazoACfMOUiZjI: "
Welkom op 3bij3 <meta name="viewport" content="width=device-width, ini", 3bij3.nl (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://3bij3.nl/.well-known/acme-challenge/DapX28z034TaJTMQRSLinxUBaOeqnnArpZTmKLRgpzU: " Welkom op 3bij3 <meta name="viewport" content="width=device-width, ini". Skipping. All renewal attempts failed. The following certs could not be renewed: /etc/letsencrypt/live/www.3bij3.nl/fullchain.pem (failure)
My web server is (include version): nginx 1.10.3
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: strato.nl
My nginx configuration is as follows:
# listen on port 80 (http)
listen 80;
server_name _;
# redirect any requests to the same URL but on https
# listen on port 443 (https)
listen 443 ssl;
server_name _;
# location of the certificate
    ssl_certificate /etc/letsencrypt/live/www.3bij3.nl/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/www.3bij3.nl/privkey.pem;
# write access and error logs to /var/log
    access_log /var/log/3bij3_access.log;
        error_log /var/log/3bij3_error.log;
        # forward application requests to the gunicorn server
                proxy_pass 127.0.0.1:8000;
                        proxy_redirect off;
                                proxy_set_header Host $host;
location /static {
        # handle static files directly, without forwarding to the application
                alias /home/felicia/3bij3/app/static;
                        expires 30d;
I do not know what is not working, please let me know if you need any additional information to help me!
You are using a proxy to redirect all queries to backend server, which also redirected the certbot query.
In order for this to work, add the following block before / after the location /
    location ~ /.well-known {
                   allow all;
Thank you
Thank you for your fast answer! I added it like this:
listen 80;
server_name _;
listen 443 ssl;
server_name _;
proxy_redirect off;
location /static {
expires 30d;
allow all;
But it still does not work, I get the same error - or did I insert it at the wrong place?
Can you please try placing that block before the first https location block (the proxy one)?
Thank you
Hey,
hmm… now it looks like this:
listen 80;
server_name _;
location /
listen 443 ssl;
server_name _;
# location of the self-signed SSL certificate
allow all;
proxy_redirect off;
location /static {
                        expires 30d;
But I still get the same issue and now when I try to reload nginx I get an error saying: nginx: [emerg] invalid URL prefix in /etc/nginx/sites-enabled/3bij3.conf:29
Sorry if I am asking stupid questions, I am completely new to this…
Ok…
That’s a little bit wierd…
Can you check your let’s encrypt renew config? (Why does using webroot produce an 404?)
listen 443 ssl;
server_name _;
              allow all;
                        proxy_redirect off;
location /static {
                        expires 30d;
do you mean this:
renew_before_expiry = 30 days
version = 0.22.2
archive_dir = /etc/letsencrypt/archive/www.3bij3.nl
cert = /etc/letsencrypt/live/www.3bij3.nl/cert.pem
privkey = /etc/letsencrypt/live/www.3bij3.nl/privkey.pem
chain = /etc/letsencrypt/live/www.3bij3.nl/chain.pem
fullchain = /etc/letsencrypt/live/www.3bij3.nl/fullchain.pem
[renewalparams]
authenticator = webroot
webroot_path = /var/www/letsencrypt,
account = a711e55840f71576a1fb61013048c7fc
installer = None
[[webroot_map]]
www.3bij3.nl = /var/www/letsencrypt
Hi @FeLoe,
Replace this:
              allow all;
by this:
    default_type "text/plain";
    root /var/www/letsencrypt;
Restart nginx and before trying to issue a certificate, first check that you can get a test file:
mkdir -p /var/www/letsencrypt/.well-known/acme-challenge/
echo "This is a test" >  /var/www/letsencrypt/.well-known/acme-challenge/test
And try to get that file from command line:
curl -ikL http://www.3bij3.nl/.well-known/acme-challenge/test
or using you browser http://www.3bij3.nl/.well-known/acme-challenge/test
If you get the text “This is a test” then go ahead and try to issue your cert.
Good luck,
sahsanu
Hey @sahsanu,
I’ve tried it, but when I do
sudo service nginx reload
it does not work and I get
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
and when looking at journalctl -xe it shows:
nginx: [emerg] invalid URL prefix in /etc/nginx/sites-enabled/3bij3.conf:30
So I cannot restart nginx…
@sahsanu @stevenzhu - found it! Apparently I needed to add http:// before the proxy_pass in nginx (although I never had to do this before) and now everything works! Thank you both so much for your help and time! I have my certificates now :wink:
