SSL renewal failing when using certbot renew
dormmarket.cz
certbot renew
Processing /etc/letsencrypt/renewal/www.dormmarket.cz.conf
Renewing an existing certificate for www.dormmarket.cz
Domain: www.dormmarket.cz
Detail: 62.72.32.119: Invalid response from http://www.dormmarket.cz/.well-known/acme-challenge/xb1zkt4gTwj-D-gAYI6UauUd3tCUJVy6IpziKFXXw5A: 404
Failed to renew certificate www.dormmarket.cz with error: Some challenges have failed.
/etc/letsencrypt/live/www.dormmarket.cz/fullchain.pem (failure)
nginx/1.18.0 (Ubuntu)
Ubuntu 20.04.6 LTS (GNU/Linux 5.4.0-1107-kvm x86_64)
Hostinger
no
certbot 2.9.0
My nginx .conf file:
    listen 80;
    server_name www.dormmarket.cz;
    listen 443 ssl;
    ssl_certificate /etc/letsencrypt/live/www.dormmarket.cz/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/www.dormmarket.cz/privkey.pem; # managed by Certbot
        proxy_pass http://62.72.32.119:8080;
My DNS records
Are you sure nginx is listening on port 80?
Try ss -tlpn src :80
This is what I see with curl
$ curl -i http://www.dormmarket.cz/.well-known/acme-challenge/sometestfile
HTTP/1.1 404 Not Found
Content-Length: 0
HTTP/1.1 302 Found
Content-Length: 0
This results in this output
State  Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0      511          0.0.0.0:80        0.0.0.0:*    users:(("nginx",pid=75658,fd=6),("nginx",pid=75657,fd=6),("nginx",pid=75656,fd=6),("nginx",pid=75655,fd=6),("nginx",pid=75554,fd=6))
Yes, i have a server running there that redirects calls to https://www.dormmarket.cz/website/index.html.
But when I do
I get this
**Server**: nginx/1.18.0 (Ubuntu)
**Date**: Tue, 19 Mar 2024 12:29:41 GMT
**Content-Type**: text/html
**Content-Length**: 178
**Connection**: keep-alive
**Location**: https://www.dormmarket.cz/.well-known/acme-challenge/sometestfile
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.18.0 (Ubuntu)</center>
</body>
</html>
Is there something I can do to make it work?
I don't get the redirect.
I get:
Content-Length: 0
I see, and what can I do to make it work. Just return HTTP 200 when someone calls
http://www.dormmarket.cz/.well-known/acme-challenge/anything
I have tried that and now I am getting this
  Type:   unauthorized
  Detail: The key authorization file from the server did not match this challenge. Expected "Yq0Yw90IWPIcm1TB6ODO4Z_grYvo9-IIfBP5F_NBtLo.4Jl8s06zaEp9BDzRtfCICEb4H-kN1tH3vW6gZ3JnFn4" (got "")
I have also tried to pass this HTML but it is also not working.
<!DOCTYPE html>
<html>
<head>
<title>Welcome to nginx!</title>
<style>
    body {
        width: 35em;
        margin: 0 auto;
        font-family: Tahoma, Verdana, Arial, sans-serif;
</style>
</head>
<body>
<h1>Welcome to nginx!</h1>
<p>If you see this page, the nginx web server is successfully installed and
working. Further configuration is required.</p>
<p>For online documentation and support please refer to
<a href="http://nginx.org/">nginx.org</a>.<br/>
Commercial support is available at
<a href="http://nginx.com/">nginx.com</a>.</p>
<p><em>Thank you for using nginx.</em></p>
</body>
</html>
What should be returned, or how should i route that call?
Should i make some changes in the DNS records or on the nginx configuration? I am a bit lost. I understand that there should some verification of the domain be happening, but what can i do?
My point was to show that we are getting two completely different replies.
Are you connecting from the same network or over the Internet?
I was executing if from the root server
You should try from the public internet.
It looks like something is handling the HTTP requests before it reaches your nginx server. Is there any kind of firewall or other protection setup in your server? Or maybe with your hosting service?
Here are some example requests
# An HTTP request is redirected but notice no "Server: nginx" response header
HTTP/1.1 302 Found
Content-Length: 0
# An HTTPS request is also redirected but see "nginx/1.18.0 (Ubuntu)"
curl -i https://www.dormmarket.cz
HTTP/1.1 302 Found
Server: nginx/1.18.0 (Ubuntu)
Date: Wed, 20 Mar 2024 21:49:16 GMT
Content-Length: 0
# A test HTTP Challenge request is redirected wrong
# It is sent to "website/security.html" which is wrong
# It should do one of these two:
# Redirect but retain the URI "./well-known/acme-challenge/Test404"
# Or, it could just reply 404
curl -i http://www.dormmarket.cz/.well-known/acme-challenge/Test404
HTTP/1.1 302 Found
Location: https://www.dormmarket.cz/website/security.html
Content-Length: 0
This pattern of responses from your server usually indicate some sort of firewall or communications device inspecting and rejecting HTTP requests.
EDIT: OR,
Do you have some kind of DNS URL redirect feature just for HTTP requests? Maybe related to some kind of "parking" setting?
Thanks a lot
I think there was this type of problem. I have a screenshot of what I did
I had to change to the recommended option in Hosting, for some reason it was on the second one and that was probably causing the error. Now I can say the certificate is renewed.
Thanks a lot to all!!
