Hi!
i have the same problem… again…
i cannot renew my certificate because of an error in certbot (or… an error in my config, to be precious)
can anybody please help me to fix it? i had to reinstall my nextcloud the last time…
thank you so much in advance!
My domain is: elberthome.dnshome.de
Processing /etc/letsencrypt/renewal/elberthome.dnshome.de.conf
http-01 challenge for elberthome.dnshome.de
Waiting for verification…
Attempting to renew cert (elberthome.dnshome.de) from /etc/letsencrypt/renewal/elberthome.dnshome.de.conf produced an unexpected error: Failed authorization procedure. elberthome.dnshome.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://elberthome.dnshome.de/.well-known/acme-challenge/r8Yjgd5t_-MMurDJZ1rz2GaoWY64v0vSeMkzL3tXnlQ: Connection refused. Skipping.
/etc/letsencrypt/live/elberthome.dnshome.de/fullchain.pem (failure)
Domain: elberthome.dnshome.de
Type: connection
Detail: Fetching
Connection refusedTo fix these errors, please make sure that your domain name was
The operating system my web server runs on is (include version): nginx version: nginx/1.10.3
My hosting provider, if applicable, is: none
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): nope, its a nextcloud running on raspbian
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
