Problem with certificate gamesyap.com
My domain is: gamesyap.com
root@ubuntu:/etc/letsencrypt/live# certbot-auto certonly -d gamesyap.com
1: Nginx Web Server plugin (nginx)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press ‘c’ to cancel): 1
Plugins selected: Authenticator nginx, Installer None
http-01 challenge for gamesyap.com
Using default address 80 for authentication.
Waiting for verification…
An unexpected error occurred:
There were too many requests of a given type :: Error finalizing order :: too many certificates already issued for exact set of domains: gamesyap.com: see https://letsencrypt.org/docs/rate-limits/
My web server is (include version): nginx 1.14
My hosting provider, if applicable, is: linode.com
Hi @techcomputerworld
you have 5 identical certificates created (Google lists 5 pre and 5 leaf certificates):
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=p:Z2FtZXN5YXAuY29tOmZhbHNlOmZhbHNlOjpFQUU9&cert_search=include_expired:false;include_subdomains:false;domain:gamesyap.com&lu=cert_search_cert
So you hit the limit.
Why don't you use one of these?
Hi, thanks for your response, I have deleted the certificates with order rm -rf directory, I’ve used certbot delete --cert-name mail.gamesyap.com and gamesyap.com, but the certiicate mail.gamesyap.co, don’t run, I want to use the mail server postfix and dovecot and the certificate gamesyap.com does not work for me it gives me the error that and it does not let me create it, delete by error.
Then you have to wait one week.
Never, never, never delete active and valide certificates.
the certificate mail.gamesyap.com don’t run, I’ve created the certificate.
certbot-auto certonly -d mail.gamesyap.com
the certificate gamesyap.com I can ask the people of let’s encrypt to invalidate the certificate that I deleted it by mistake
This doesn't change something. Please read
Revoking certificates does not reset rate limits, because the resources used to issue those certificates have already been consumed.
Is it posible use let’s encrypt certificates, for mail server?
Yes, it's possible. You have three:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:mail.gamesyap.com&lu=cert_search
