Problem with auto-renew on apache
Hello, im trying to execute the following command: certbot renew --dry-run -v
My goal with this is to check my automatic renew is working fine.
I having the following problem answer:
Processing /etc/letsencrypt/renewal/example.example.com.conf
Certificate is due for renewal, auto-renewing...
Plugins selected: Authenticator apache, Installer None
Simulating renewal of an existing certificate for example.example.com
http-01 challenge for example.com
Challenge failed for domain example.example.com
http-01 challenge for example.example.com
Domain: example.example.com
Detail: 3.224.140.186: Invalid response from http://example.example.com/.well-known/acme-challenge/BooXbwK_y6moaaFFgmSD1M8p_n5YR-_0EN0M3uWWzzo: 403
Failed to renew certificate example.example.com with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/example.example.com/fullchain.pem (failure)
It seems to show the 403 problem code, this is some kind of permission? Thanks
Obs: using example.example.com instead the orginal domain just for the ticket.
A 403 error with the --apache authenticator usually means a problem with the Apache config. In this case my first guess would be multiple VirtualHosts for port 80 with the same domain name.
Or, you are issuing the 403 in a firewall or similar for the incoming requests.
What does this show? Please don't redact the domain name. That will probably also hide the underlying problem.
sudo apache2ctl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443 misp.csdbr.com (/etc/apache2/sites-enabled/misp.csdbr.com-le-ssl.conf:2)
*:80 misp.csdbr.com (/etc/apache2/sites-enabled/misp.csdbr.com.conf:1)
the problem could be this plugin with "Installer None"?
No. That just means you originally used sudo certbot certonly --apache ... (or other method) to use --apache plugin only as authenticator. It is perfectly normal method.
Would you show contents of this file
Im did the following command:
certbot certonly --webroot -w /var/www/html -d misp.csdbr.com
This make me use the webroot to validade, for my surprise, this works fine and the simulate renew shown as "succeeded", now I will wait for the day of the auto renew and check. thanks for the support.
You may need to restart/reload anything that is using the renewed cert(s).
Good. You can re-try your sudo certbot renew --dry-run before that to check that it should work
The --apache authenticator would reload Apache so it saw fresh certs. Well, it probably would depending if you version supported it. But, --webroot does not without using a --deploy-hook.
If you have a current Certbot version you can add a deploy hook with:
sudo certbot reconfigure --cert-name misp.csdbr.com --deploy-hook 'systemctl reload apache2'
When asks if you want it run during --dry-run respond r for Run (yes).
I used systemctl reload apache2 as an example. Use your preferred command.
